Now that I've got my turn signals mounted, I'd like to get rid of the huge original rear brake light/plate holder. It works fine, I just want something smaller and don't want to chop off the OEM mounting points from a perfectly good tail light.
Are there any Honda OEM or aftermarket lights that are compatible with the GL1100 bolt hole pattern? I also don't want to drill out a perfectly good fender.
Looking for incandescent lights rather than LED.
Thanks for any ideas
Bolt hole compatible brake light/plate holder?
toomanybikes
Asheville, NC, USA
Stable as of 09Oct25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '81 Honda GL1100, '82 Honda V45 Sabre, '10 BMW R1200RT, '16 Moto Guzzi Audace
Re: Bolt hole compatible brake light/plate holder?
Go on ebay. Thousands of options.
toomanybikes
Yeah, i realize that. i was hoping to narrow the field a little to ones that will match the mounting points, unless you think ebay has 1000's wit the same bolt holes.
Asheville, NC, USA
- BikeMaine
The bolt holes will most likely be different than stock.
To me, there's no reason NOT to drill new holes. The fenders are not rare, the bikes aren't that rare.
But if you don't want to drill, make a simple adapter plate to keep the originals.
Kevin
1982 GL1100A
1982 GL1100A
- gregforesi
I'm sure I'm not the only one who feels that finishing out the back of a motorcycle is the hard part.
It's gotta have:
You have options ranging from custom bracketry that will fit the stock fender holes but adapt to your new light housing, or altering the stock housing and lens, or going full custom with a new fender to butcher yourself.
In the end, you just need to be able to get the wheel off without taking half the bike apart, or having to rewire it.
(I would suggest not going "minimalist" with the brake light UNLESS you go with multiple lights to make up for size.)
It's gotta have:
- Brake lights
- Turn indicators
- Registration plate
- A light for the registration plate
- Maybe a "5 to 4" wiring adapter (depending on the lights)
- Maybe a fender.
2006 GL1800 (Brutus Maximus)
- BikeMaine
One could also buy a used rear fender for cheap and drill that one, saving the original.
Kevin
1982 GL1100A
1982 GL1100A
- kerryb
You could make a custom enclosure from fiberglass. Carve a block of rigid foam to the shape you want, lay fiberglass cloth over it with epoxy. Strip out the foam, & drill holes for mounting. This is a custom airbox made to fit under the seat, between the frame rails for my honda cb650.
