New Tool for Float Bowl Level Verification
Re: New Tool for Float Bowl Level Verification
Thank you, Cedric. Water doesn't stink, as well.
EDIT March 15th-
isopropyl alcohol was suggested as a rubber safe testing liquid in another member's Topic. I will try it...
Cliff ;) )
POST#17
cfairweather wrote: Mon Feb 12, 2024 9:35 am snip-
...the key is to adjust the floats where the level is at the lower edge of the lip. see Post#1 tumb2
These clear tubes were designed to be used only when the carbs are off the bike and on a stand,
https://ngwclub.com/forum/viewtopic.php?t=78581
I set-up this GL1000 carburetor rack on my pickup's tailgate. note the protractor I used to level the tailgate test surface.
Isopropyl alcohol was perfect test fluid.
Here's the results....
Yes, the New Tool for Float Bowl Level Verification works Very Well action1 tumb2
The purpose of this inverted photo of the carburetor rack is only to present why the # 4 ( also #1 ) carburetor body's flange isn't touching its vertical transparent fluid level testing tube.
If you absolutely must see both vertical fluid level tubes OD touching their respective carburetor body flange, temporarily swap on two fuel bowls with switched position drain screw holes borrowed from another pair of GL carburetors. ( id est .. carburetor positions numbers 3 and 2 )
Cliff ;) )
Pretty sure many of your pick flipped upside down. Based on the gravity I know of and the drain screw on the bottom of the bowls.
They all look right side up to me (except maybe the last one where the carbs are sitting upside down).
POST#20
ooops...I should have made the previous testing photos delineate the actual Verified Float Bowl fluid content Levels
The isopropyl alcohol is easily drained out of the float bowls.
Cliff ;) )
i'm pretty good at setting the float levels with the Randakk tools,... but I love that tool for double checking the levels. I would even say it is a great tool to start with
redglbx
Post by redglbx »
Cyborg, totally agree ! I’m pretty good at the carb setup but this is a great tool for checking the setup ! I’ve learned over the years the more equal and consistent cylinder to cylinder you can make things on these bike the better they will run. And this is one more way to check it all.
Good job Cliff !
Thankyou for doing these Cedric, now I just need to check mine on a good back day,,,, but to be honest I’m a little afraid to check and find out I’m not nearly as good at this as my ego thinks it is…..😁😁
cfairweather
Post by cfairweather »
Don't be surprised if a couple of them need to be adjusted. I have set many of them very carefully with the gauge and then had to adjust them. Honestly, I don't even use the gauge much these days. I usually adjust them visually and by feel, then check them with the visual float gauge tool. I agree that it is best to get these all set to the same level so the carbs are as equal as possible. After setting the floats with a gauge, I have found that the level will be as high as the middle part of the rim. You do not want the level to exceed the middle part of the rim and I believe the best point it at the lower edge, just as Cliff has them set. If you set the level higher than the middle of the rim, expect your carbs to overflow at some point. Stick with the lower edge if you wat to be safe. Also, I don't even install the float bowl gasket when I set the floats. I just use two screws for the bowls until I get them all set correctly. Don't forget to verify when the floats OPEN the valve too as this is just as important as when the floats close the valve. I wrote more about this in another thread.
CYBORG wrote: Fri Mar 15, 2024 8:26 pm i'm pretty good at setting the float levels with the Randakk tools,... but I love that tool for double checking the levels.
Agreed Doug tumb2
This excellent Float Bowl liquid Level Verification Tool and my *must have* carburetor pressure test air pump tool, to verify if liquid fuel circuit sealing components are intact. ;)
'nuff said :)
Cliff ;) )
good idea to preasure test. I usualy just hang a remote tank about 8 feet up.
dontwantapickle
Post by dontwantapickle »
Who decided that 20+ lbs. of air pressure was a sufficient amount to determine that the fuel system is sealed?
IDK much compared to some of you guys,
but that seems like an awful lot of pressure to me.
Cliff ;) )
#28
dontwantapickle wrote: Sat Mar 16, 2024 11:25 pm Who decided that 20+ lbs. of air pressure was a sufficient amount to determine that the fuel system is sealed?
i agree. hard to believe the valves in the carbs would even hold that much . the pump only puts out about 5 on a good day
#29
CYBORG wrote: Sun Mar 17, 2024 8:11 am
Think about it though. That pump is "sucking" on the valves. So the more pressure the harder it "pulls" on the rubber tipped valve. Not really an accurate test IMO.
cfairweather
#30
I agree with Robin, but it would be a good test for the plenum fuel seals. I test these with a vacuum pump as Randakk suggests with rubber plugs in the holes, but the rubber tipped float valves accomplish the same thing.
