The Aspy Project
Re: The Aspy Project
tires look SWEET!
did I miss the part about where you sourced your new brake lines?
I ask because I would like to do mine as well and since we have twins...
I've looked at several places and didn't really trust any of them. if you wouldn't mind, at your convenience, passing along some contact info.
H2G2=42
H2G2=42
I've gotten three sets now from Apexbrakes.com. This last time I had problems with the website so I just emailed Raymond Chan @ havetodoit@hotmail.com. Decent price, fast turnaround, and quite responsive. I've seen posts of his on Facebook as well.
The tires are Shinkos 777 'reinforced' "for heavy cruisers and touring" and they are beasts! I've had good luck with other Shinkos, so we'll see how these do.
aHA! he comes highly recommended! (I have contacted him yet)
did you just order lines for an '86 or didja have to give him measurements for each line?
Thanks for the info!!
H2G2=42
H2G2=42
I just ordered them for an 86 Aspencade. Finished the install today, and all went well, good fitment. Just an FYI, just plan on removing the fairing and mounting bracket as one unit. I figured I could just loosen the fairing from its bracket. What a PITA!
As mentioned earlier, if you're replacing the clutch lines as well, you'll need to cut and double flare the hard line between the flex lines. I passed on that project for the time being...
After pulling the rear master cylinder, I found I had somehow contaminated it with grease, so that needed to be cleaned out. Tried again with the hand vac, no joy. Even broke the pump handle! Grrrrrr!
Rechecked the lines and found the front line connection was leaking (of course it's the one that's buried under everything in the fairing...
Then I had to figure out how to bleed that mile long line... Popped in a sync adapter, ran a line to the bleeder, and started the engine. While the vacuum is a pulse, it worked great! Fifteen minutes later, I had both front and rear brakes!
The final touches, other than an oil change, will be upgrading and adding some extra lighting (the necessary stuff, not farkles, lol! ).
- ritalz
Lookin good. Some road testing miles and you will be ready for next month's run.
Scrubbed in the tires on a 100 mile jaunt yesterday, and aside from needing to tweak the brake bleeding a bit, everything looks and feels hunky-dory.
As for being ready for next month's run, it looks like that's not going to happen.
- ritalz
I hear you about the expenses. I'm still planning on being there with limited spending for sure. I too could use a new helmet but a lift table is not in my seeable future. Even if it was, I don't have a garage to store it in.
Well... as we all know, 38 year old vehicles always seem to need something or another attended to...
On my last ride before winter hibernation, the 1200 (now named Daisy, BTW) had a major electrical failure. Symptoms pointed to a poor battery, and I chalked that up to its age and the fact that I didn't ride at all toward the end of the season. I had noticed no problems previously.
Being that it was headed to storage anyway, I didn't investigate deeper, figuring she'd get a new battery this spring, and all would be good. Ummm, nope! I did find one electrical issue fairly quickly; the ignition switch contacts were heavily oxidized. Good to go, right?
Hardly got 15 miles in on my first ride this spring, and had the same issues, I would lose all instrument displays and headlight randomly, the engine would cut out then restart, etc.
Limped her home and dug out the multimeter. Not charging! Grrr! Snipped the previously soldered three yellow wires, and had my quick and painful answer. All three wires tested continuity to ground. Looks like an alternator adaptation is in my future...
I fabed one from scratch, with alot of help from Cyborg. Not that hard..
Yes, it seems pretty straight forward, although there's some controversy concerning the pulley size, etc. Electrical functions are not my specialty, either, so I'm sure I'll be stumbling through it.
I need to take a short hiatus from my frustrations, so I moved her back to storage for a bit which will allow me to concentrate on fitting out my shop. Right now I'm running to the storage shed and rummaging through various tool boxes and bins every time I need something...
Don't get too organized......takes away from creativity
