1975 GL1000 project
Re: 1975 GL1000 project
New timing belts installed. I am cleaning up the covers before I install them. I didn't remove radiator, just took off water pump cover.
Thank you, Don B.
- Old Fogey
Rebuilt rear master cylinder, piston didn't want to come out. So I said "screw it". Cleaned bore up with hone and replaced 2 part brake line with 1 braided line.
Thank you, Don B.
