Center stand cross member replacement.
DUGG
Post by DUGG »
Late last summer while doing some maintenance on my gold wing the center stand gave out when I tried to get it back on the floor. I had noticed an odd wobble to the motorcycle went on the center stand. I used a floor jack while balancing the motorcycle with one hand and got it back on the ground. I rode the bike maybe twice more and then parked it
After about two hours of removing stuff I had a very naked Goldwing
DUGG
Re: Center stand cross member replacement.
Post by DUGG »
The crossmember was pretty rotted out on both sides so chose to remove and replace it as opposed to plating over it
DUGG
Post by DUGG »
After cutting out the crossmember I cut off the rest of the rotted out portions. I found a piece of heavy wall 1 inch tubing fit perfectly inside of the existing crossmember piece.
DUGG
Post by DUGG »
I left a knob on either side of the frame that the new piece of 1 inch tube would sit in and hold it in place.
At this point of need to figure out the angle of the dangle so to speak so that the center stand works correctly. Will probably also blast the areas with a soda blaster to remove the rust before welding it all into place
Same exact place mine rotted out.
pidjones
Post by pidjones »
I had an early '78 frame rotted out like that last year, but had a '79 frame that couldn't be used due to head stock damage that had very good lower frame pieces. A very good friend (a nuclear welder) cut out the sections from each and spliced the '79 section into the '78. It was interesting to note that the '79 had extra gussets not present on the '78.
DUGG
Post by DUGG »
It’s interesting that the 79 had extra gusset but these 81 does not. The other thing is how does water get inside of this thing to rusted out. Seems to be a pretty common problem on these old wings
Don R
Post by Don R »
I think I'll have a look under my 78 after seeing this recently. Thanks for the heads up.
There are lots of places on the frame that aren't sealed. There should be drain holes so that the water can escape but they often become blocked. I like to add some creeping rust proofing oil into some of the upper openings so that it can spread over the interior of the frame to protect it (put something underneath to catch the drips for a few days if you do this and don't forget about the hollow pressed steel lugs attached to the frame that have separate openings and drain holes).
DUGG
Post by DUGG »
Unfortunately this project has to a halt because the motor that feeds the wire on my welder died. The machine is 20+ years old and the part is no longer available. So hopefully the next day or two I’ll be able to pick up a new welder and continue with this.
DUGG
Post by DUGG »
Sidecar Bob wrote: Sat Apr 17, 2021 2:47 pm There are lots of places on the frame that aren't sealed. There should be drain holes so that the water can escape but they often become blocked. I like to add some creeping rust proofing oil into some of the upper openings so that it can spread over the interior of the frame to protect it (put something underneath to catch the drips for a few days if you do this and don't forget about the hollow pressed steel lugs attached to the frame that have separate openings and drain holes).
I’ve looked for drain holes but haven’t found any. Can anyone show me where they are at?
DUGG
Post by DUGG »
Ah... thanks Sidecar
DUGG
Post by DUGG »
Back in business. About $1100 later for a new welder and splurge on a new helmet I could put a cheater lens in so I can see what I’m welding. Sucks to get old.
DUGG
Post by DUGG »
I notched the upper part of the old cross member on the left side. This way my new piece could fit snugly between the frame
The only way I could figure to locate the new crossmember correctly was to use the bump stop for the center stand. So I removed the bracket from the exhaust system and bolted to the frame and used a pair of vise grips to hold a stand in place while I tacked it with the welder
