Servicing a GL1000 this fine afternoon. Customer wants it to run better than it does. Checking cylinder compression as a first step, with anticipation it will be low because it usually is in these machines, and counting on some fine tuning of valves and ignition and a carb rebuild. Fun project... Whoa! 200 psi! That's some compression! Wait! There can't be that much carbon in there! Hmm, if I didn't know better... Off come the belt covers and aha...! Both cams are advanced. Unusual. Retarded, you expect. One, that's typical. But both advanced? That means the engine didn't do this, a human did it. And what about the guy that just "tuned" this bike? Well, this has been a fruitful afternoon. Now I know why the compression is so high and more importantly, I can give the customer a good prognosis because now I know why two weeks ago another mechanic had the carbs off the bike three times. Being methodical has paid off once again.
