I want this GL 1500
- Buli
I want this GL 1500
I really really really would like to build something like this. I bet the sound give you goosebumps
Kinde
Re: I want this GL 1500
Wow! That is one sweet looking bike. Don't know for sure, but probably based on a Valkyrie?!?
- Buli
El equipo de Dragon’s Motorcycles liderado por Pablo Pérez, se coronó con el máximo galardón de esta nueva edición del concurso. Se presentó en la categoría Race & Racing con una motocicleta, denominada Honda 1500 Super Sport, realizada sobre la base de una GL 1000 de 1977, uno de los motores más impresionantes construidos por Honda. El ganador logró en primer término el primer puesto de su categoría y, posteriormente, obtuvo el máximo galardón del certamen. Dragon’s Motorcycles se llevó un total de tres mil euros en metálico de premio.
Google trans
The Dragon’s Motorcycles team, led by Pablo Pérez, was crowned with the highest award of this new edition of the contest. It was presented in the Race & Racing category with a motorcycle, called Honda 1500 Super Sport, made on the basis of a 1977 GL 1000, one of the most impressive engines built by Honda. The winner won first place in his category and then won the highest prize in the contest. Dragon’s Motorcycles won a total of three thousand euros in prize money.
So i only need a 77 frame and 1500 engine hahaa. Will see
Google trans
Kinde
From the few pics, the swing arm area of the frame looks to be from a 1000, but I can't really tell if the swing arm itself is from a 1000. IIRC, the output shaft of the 1500 is offset farther from the centerline of the engine, and obviously the engine is significantly longer, so considerable fabrication would be required throughout. It would be a fun challenge, no doubt!
I’ll bet that doesn’t get tested at speed. It’s very clean, but I can’t see much in the way of frame reinforcements that early Wings were known to suffer from. If it has a 77 final drive, it would scream. There have been a few 1500’s stuffed into early wings over the years. Never heard of how well they performed.
There's a vid out on the webby somewheres that show it running, and the Honda emblems on the tail swing around for turn signals...
- Buli
i found this vid. The sound is not what i expected. Maby it is the poor microphone
Kinde
From the vid it looks like a GL1000 rear drive.
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
- 16 Replies
- 2995 Views
Last post by lcallison
- 4 Replies
- 1114 Views
Last post by wingrider
- 38 Replies
- 2802 Views
Last post by doubleminded
