Tip for brake caliper piston removal
terryjenner
My Album: http://s1140.photobucket.com/albums/n57 ... %20top%20e
Post by terryjenner »
I tore my brake master cylinder and calipers down today. You need a soft-jawed vise but I only have the aluminum-destroying version of vice jaws. My solution was to clamp a large Jorgensen wood vise into my vise, then clamp the part I was working on into the Jorgensen clamp. It worked great.
In order to keep the piston from flying out as a projectile, I put a block of wood in between the piston top and caliper bracket. As the piston worked its way out a bit, I decreased the dimension of the free space between the piston top and the free world so it wouldn't just shoot out and take me out with it.
If I had my SD card in my camera phone I would have taken a pic, but I can if anyone wants.
Terry
(2) 1975 GL 1000
97 VFR 750
07 CRF 250x
IndianaJohn
Re: Tip for brake caliper piston removal
Post by IndianaJohn »
I usually just do it on the bike. Unbolt the caliper and let it hang, then just use the master to pump the piston out. Just did this on the 750 a couple of weeks ago. Of course I overhauled the master first.
IJ
Stupid people shouldn't breed.
75 CB750
76 GL1000
82 Yamaha XV920J Virago
81 Yamaha XV750 Virago (parts)
RIP: 1950-2011
Post by Cookie »
Some of those are amazingly stuck though. I've had a long sitter just blow the master. I have been lucky enough not to have had to go the grease gun method yet.
IndianaJohn
Cookie wrote:Some of those are amazingly stuck though. I've had a long sitter just blow the master. I have been lucky enough not to have had to go the grease gun method yet.
Never had to resort to that method either, but I have heard of people doing so. I've used air in the past and decided pumping them out with the master was safer. But if that failed, I might have to go with the grease gun, tho I would dread the clean-up afterward.
IJ
75 CB750
76 GL1000
RIP: 1950-2011
Post by Cookie »
Air just made noise on the last couple until I boiled them. The rear took boiling twice. At least I didn't have to deep fat fry them! :-D
milesoffun
Post by milesoffun »
I used the grease method and it was not near as bad to clean up as I thought it would be - 10 minutes and I was good to go.
MilesOfFun
80 GL1100 - Yellow (Got wet due to Huricane Sally - gonna give it a try!)
83 GL1100I - Blue (Got wet due to Huricane Sally - but gonna give it a try!)
morganfrmn
My Album: http://www.ngwclub.com/gallery/main.php?g2_itemId=2743
Post by morganfrmn »
take both apart and use the master cylinder on both at same time... till they get to the end...
Click here and you can see my motorcycle
(http://www.ngwclub.com/gallery/main.php?g2_itemId=2743)
(http://www.facebook.com/morganfrmn)
DocRoot
Post by DocRoot »
Sprout and I just did mine (barnfind 1100) which were amazingly corroded and stuck, and it was no-muss, no-fuss, well, maybe just a little muss:
Appreciate good people: they are hard to come by.
DocRoot
Post by DocRoot »
We used the banjo and plugged it with a short piece of copper #14 wire with a bit of the insulation still attached, stuffed up the center and then screwed back in.
You can see the amount of grease the two sides took altogether.
DocRoot
Post by DocRoot »
The best part of the grease-gun method is that they come apart with no drama. The HUGE pressure of a grease gun is backed up by really low volume so when things let go it is in millimeters, not with a pop or bang... Things ooze, they don't squirt.
Now it's off the the ultrasonic cleaner for some R&R.
pidjones
Post by pidjones »
I've done grease gun, air, and master. I think my favorite is actually the grease gun. A little kerosene bath for it after...
tomk1960
Post by tomk1960 »
If air doesn't work, this is the method I use that ALWAYS works, every time. And no greasy mess to clean up afterwards.
https://www.youtube.com/watch?v=rHvIA_--BAs
1986 VFR750F Interceptor
1983 Honda CB1100F Super Sport - Red 1123 Resto-Mod
1978 Honda GL1000
SnoBrdr
Post by SnoBrdr »
I had to do it.
Cleanup wasn't really that bad.
A can of Brake Kleen easily did the trick.
78 GL1000 Original Owner 131k
pidjones
Post by pidjones »
I'd much rather deal with the grease than more brake fluid.
You have to clean them anyway ....
Gord(greasey)Jones :lol:
