Tip for brake caliper piston removal
Moderators: robin1731, CYBORG, Oldewing, Forum Moderators
terryjenner
My Album: http://s1140.photobucket.com/albums/n57 ... %20top%20e
Post #1 by terryjenner » Sun May 23, 2010 6:16 pm
I tore my brake master cylinder and calipers down today. You need a soft-jawed vise but I only have the aluminum-destroying version of vice jaws. My solution was to clamp a large Jorgensen wood vise into my vise, then clamp the part I was working on into the Jorgensen clamp. It worked great.
In order to keep the piston from flying out as a projectile, I put a block of wood in between the piston top and caliper bracket. As the piston worked its way out a bit, I decreased the dimension of the free space between the piston top and the free world so it wouldn't just shoot out and take me out with it.
If I had my SD card in my camera phone I would have taken a pic, but I can if anyone wants.
Terry
(2) 1975 GL 1000
97 VFR 750
07 CRF 250x
IndianaJohn
Re: Tip for brake caliper piston removal
Post #2 by IndianaJohn » Sun May 23, 2010 11:46 pm
I usually just do it on the bike. Unbolt the caliper and let it hang, then just use the master to pump the piston out. Just did this on the 750 a couple of weeks ago. Of course I overhauled the master first.
IJ
Stupid people shouldn't breed.
75 CB750
76 GL1000
82 Yamaha XV920J Virago
81 Yamaha XV750 Virago (parts)
RIP: 1950-2011
Post #3 by Cookie » Mon May 24, 2010 2:10 pm
Some of those are amazingly stuck though. I've had a long sitter just blow the master. I have been lucky enough not to have had to go the grease gun method yet.
IndianaJohn
Post #4 by IndianaJohn » Mon May 24, 2010 2:35 pm
Cookie wrote:Some of those are amazingly stuck though. I've had a long sitter just blow the master. I have been lucky enough not to have had to go the grease gun method yet.
Never had to resort to that method either, but I have heard of people doing so. I've used air in the past and decided pumping them out with the master was safer. But if that failed, I might have to go with the grease gun, tho I would dread the clean-up afterward.
IJ
75 CB750
76 GL1000
RIP: 1950-2011
Post #5 by Cookie » Mon May 24, 2010 3:30 pm
Air just made noise on the last couple until I boiled them. The rear took boiling twice. At least I didn't have to deep fat fry them! :-D
milesoffun
Post #6 by milesoffun » Mon May 24, 2010 3:33 pm
I used the grease method and it was not near as bad to clean up as I thought it would be - 10 minutes and I was good to go.
MilesOfFun
80 GL1100 - Yellow
83 GL1100I - Blue
80 GL1100I (In Waiting!)
68 CT90 - perfectly simple one kick wonder
69 CT90 - very rough but working on it
72 SL125 (In Waiting)
65 Allstate/Vespa (In Waiting)
77 Bianchi Snark in pieces
morganfrmn
My Album: http://www.ngwclub.com/gallery/main.php?g2_itemId=2743
Post #7 by morganfrmn » Mon May 24, 2010 5:34 pm
take both apart and use the master cylinder on both at same time... till they get to the end...
Click here and you can see my motorcycle
(http://www.ngwclub.com/gallery/main.php?g2_itemId=2743)
(http://www.facebook.com/morganfrmn)
DocRoot
Post #8 by DocRoot » Sun Jun 16, 2019 5:07 pm
Sprout and I just did mine (barnfind 1100) which were amazingly corroded and stuck, and it was no-muss, no-fuss, well, maybe just a little muss:
Appreciate good people: they are hard to come by.
DocRoot
Post #9 by DocRoot » Sun Jun 16, 2019 5:09 pm
We used the banjo and plugged it with a short piece of copper #14 wire with a bit of the insulation still attached, stuffed up the center and then screwed back in.
You can see the amount of grease the two sides took altogether.
DocRoot
Post #10 by DocRoot » Sun Jun 16, 2019 5:14 pm
The best part of the grease-gun method is that they come apart with no drama. The HUGE pressure of a grease gun is backed up by really low volume so when things let go it is in millimeters, not with a pop or bang... Things ooze, they don't squirt.
Now it's off the the ultrasonic cleaner for some R&R.
pidjones
Post #11 by pidjones » Sun Jun 16, 2019 7:49 pm
I've done grease gun, air, and master. I think my favorite is actually the grease gun. A little kerosene bath for it after...
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
Ex '75 RD400
tomk1960
Post #12 by tomk1960 » Sun Jun 16, 2019 8:36 pm
If air doesn't work, this is the method I use that ALWAYS works, every time. And no greasy mess to clean up afterwards.
https://www.youtube.com/watch?v=rHvIA_--BAs
2011 Kawasaki Vulcan 1700 Nomad
1986 VFR750F Interceptor Project
1983 Honda CB1100F Super Sport - Red
1983 Honda CB1100F Super Sport - Blue Resto-Mod
1983 Honda CB1100F Super Sport - Red Resto-Mod
1978 Honda GL1000
1974 Honda CB750K4
SnoBrdr
Post #13 by SnoBrdr » Sun Jun 16, 2019 8:51 pm
I had to do it.
Cleanup wasn't really that bad.
A can of Brake Kleen easily did the trick.
78 GL1000 Original Owner 131k
pidjones
Post #14 by pidjones » Sun Jun 16, 2019 10:27 pm
I'd much rather deal with the grease than more brake fluid.
Ex '75 RD400
RAT
My Album: http://www.ngwclub.com/gallery/v/wingmans/rat/
Post #15 by RAT » Mon Jun 17, 2019 8:27 am
You have to clean them anyway ....
Gord(greasey)Jones :lol:
'82 GL1100 Interstate 'R2B5' (Rat 2 Be 5)
1984 GL 1200 Standard 'R2B4' SOLD ....
Team 898, Team LTD 993 and Team '76 R2B3
Who is online
