1981 GL1100 Standard-detailed refresh and mechanical update.
flyin900
Re: 1981 GL1100 detailed refresh and mechanical update.
#46
Post by flyin900 »
It seems the listing has been taken down. The seller indicated only one set left after I purchased, so maybe their O/S now. The seller is Otto_ classicbikes on EBay out of Thailand.
Current Bikes:
Jonesz
#47
Post by Jonesz »
flyin900 wrote:It seems the listing has been taken down. The seller indicated only one set left after I purchased, so maybe their O/S now. The seller is Otto_ classicbikes on EBay out of Thailand.
Thanx for the info. I will try again in a few days see if stock shows up
Jonesz
1979 Suzuki GS850. Sold
#48
Jonesz wrote:So it appears I am a dufus. Can't locate the seller or the item by using the item number?
Yeah, a link would make it a lot easier.
flyin900
#49
Post by flyin900 »
Unfortunately I don't know how to link to the original ad. When I click on it now it states the seller has modified the ad and lets me see only my original purchase. I suspect the seller has sold out and taken the ad down. It shows he sold over 350 sets of these, so I would think he was successful and may get more stock again.
There are other sellers on EBay with a like product, yet the correct size is approx 195mm length X 25mm height and some of the other sellers items are too small.
Current Bikes:
JamesPal
#50
Post by JamesPal »
I saved the seller. When I looked at the ad is said there was only one item left. Here is his store: https://www.ebay.com/str/ottoclassicbike
'85 GL1200I
'81 GL1100 STD
'72 CB450
flyin900
Back in business on this one.
#51
Post by flyin900 »
With the help of a couple of CVMG club members we were able to get the frame and running gear out of the basement and back into the garage. I was able to get the motor and then the carbs and the drive line reconnected over the past few days. The next step will be putting the gas tank back into the frame without removing all that nice new paint off the sides.
Hopefully the weather will co-operate further in the coming weeks and I can shoot the refresh of the clear coat on the body panels and move this towards completion.
Here's how it looks presently and I am pleased with how the overall finish and reconnection of components has gone so far.
Current Bikes:
Re: 1981 GL1100 Standard-detailed refresh and mechanical update.
#52
Very nice! Very clean!
#53
spiffy!
Maroonandwhite
#54
Post by Maroonandwhite »
Looking great! I'm following this thread intently, as it has helped me on my GL1000 build already.
maury
#55
Post by maury »
Paint turned out real nice for sure.
What primer did you use?
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
flyin900
#56
Post by flyin900 »
On the frame I just used an inexpensive grey rattle can primer from a local shop where I buy mostly tools. They had a deal on this self etching primer and it looked decent. The motor I used a Duplicolor self etching primer that is in a rattle can and fairly expensive. I have used it numerous time before on motors first before shooting the silver engine enamel and it has held up really well on those bikes.
The black frame paint was a two part body shop mix with hardener and it has sat and cured over the winter, so it has set up very well. If you go back into the early posts in this thread there is information on the paint brand and model numbers that I used.
Current Bikes:
PDub
#57
Post by PDub »
+1 on the etching primer. 4 years ago I replaced the clutch lever on another bike. The replacement was silver anodized but I needed black. Cleaned and sanded the lever, applied etching primer, painted it black and baked it. Wasn't sure it would hold up but it still looks like it came from the factory.
"Looks and functionality are two different issues. It's like buying what appears to be a showroom kept bike and you get that "wow that's a bike I want" feeling, then you get it home and start the maintenance and voila, here come the skeletons from the closet." - Rednaxs60
1976 GL1000
1988 NT650 (Hawk GT)
1971 CB175
1965 S90
1972(?) CT90
flyin900
#58
Post by flyin900 »
A little more progress as I got the gas tank into the frame with no major scrapes or really any issues. WD40 is your friend on the rubber bits, as it makes for a slippery surface. I was able to get the carbs, shocks, battery box and associated wiring plus the rear end drive unit and C clip on the drive shaft in place relatively easily. I have just received new tires, so the next trip will be to get these mounted and balanced and install the exhaust system.
Spring has been MIA around here for all of April with very few days above 10C, so shooting some clear coat to refinish the body panels will have to wait a little longer. I should be able fire the bike up again at some point next week, if everything continues on pace.
Current Bikes:
JamesPal
#59
Post by JamesPal »
Looking very nice, this is going to be a runner. Keep up the photos- THX
'85 GL1200I
'81 GL1100 STD
'72 CB450
#60
You do nice work!!!
