Found this nice '78 and now the resurrection begins...
desertrefugee
Re: Found this nice '78 and now the resurrection begins...
#76
Post by desertrefugee »
Love those F models. Ever since the "original" SOHC Supersport. I registered over there. Maybe they'll accept a CBX'er. It's essentially an F anyway...
Thanks for the link!
tomk1960
#77
Post by tomk1960 »
desertrefugee wrote:Love those F models. Ever since the "original" SOHC Supersport. I registered over there. Maybe they'll accept a CBX'er. It's essentially an F anyway...
A bunch of guys on the 1100F forum have CBX's. Your CBX is the 6 cylinder big brother to our DOHC's and is highly coveted. Come on over!
1986 VFR750F Interceptor
1983 Honda CB1100F Super Sport - Red 1123 Resto-Mod
1978 Honda GL1000
#78
the gold wheels really set off the gold pinstriping. nice work
tomk1960
#79
Post by tomk1960 »
I finally got the front end back together and on the bike. Disassembly, cleaning, pulling those stubborn fork seals, powder coating, and rebuilding took all the time. Sliding the tubes in and bolting on the 900C fender and wheel took no time at all. Like they always say - it's all in the prep.
Next will be the calipers and rear fender.
1978 Honda GL1000
desertrefugee
#80
I love that 900C fender. I used one too. Perfect match for a sport GL1000. I bought it with the intention of painting it black, but the chrome was so nice with no rust even underneath that I used it in chrome instead.
Looks like you got a really nice specimen, too.
Hanslehoff
#81
Post by Hanslehoff »
Looking really good! Loving the gold wheels and rotors
TorontoGL
#82
Post by TorontoGL »
go for it, love the colour
Honda gave Wings
1976 GL1000 LTD X 2
1979 GL1000 Blue
1969 CB350
1966 CB450
1963 CB77
1974 CB550K
1975 CB550F
1977 CB400F
2009 Road King
and few more hondas
tomk1960
#83
Post by tomk1960 »
More progress...
Brakes are all set front and back, rear fender installed, handlebars, controls, and grips all in place. There are a few mods that should be obvious.
Time permitting, the carbs will go back on this weekend and then I just have to adjust the valves, install fresh valve covers and gaskets, install the Harley take-off mufflers, and button everything up. My goal is to finish by the end of the month, so I might just make it. ;)
1978 Honda GL1000
tomk1960
#84
Post by tomk1960 »
More progress over the weekend. Carbs installed, muffler brackets fabricated and Harley take-off mufflers installed. I'm hoping to wrap this up by next weekend. Getting anxious to fire this one up!
1978 Honda GL1000
tomk1960
#85
Post by tomk1960 »
This past weekend I went through the punch list and ticked off most of the items, which included:
  • Made custom-length throttle cables to accommodate the shorter bars using a Venhill universal throttle cable kit
    Adjusted the valves and installed new valve cover gaskets and restored covers
    Bled the front brakes
    Installed Harley mufflers for good
    Filled the radiator
Last night I hooked up an aux. fuel tank and tried starting it. Pressing the starter button only dimmed the lights - no click, no starter engagement. I shorted out the solenoid and once the carbs filled with gas, the bike fired up. Finally! It sounds good so far.
I'm assuming that my solenoid is junk, based on the symptoms described. Any comments or suggestions? New aftermarket solenoids aren't very expensive, so maybe I should just order one and pop it in.
My goal was to have this running by the end of September. I just made it!
1978 Honda GL1000
#86
sure sounds like the starter relay, I am assuming you jumped across the lugs on the relay. I have no experience with after market ones, but a relay is a relay
BTW in August picked up a 78 "parts" bike (has most of the parts. trying to save the "best looking" one bike at a time
tomk1960
#87
Post by tomk1960 »
rcmatt007 wrote:sure sounds like the starter relay, I am assuming you jumped across the lugs on the relay. I have no experience with after market ones, but a relay is a relay
Yes, I jumped across the lugs to start the bike. So 12 from the battery is getting there. I'll make sure that the signal from the starter switch is also getting there.
What color is the '78 you picked up? Is it naked or do you have to undress it for restoration?
1978 Honda GL1000
#88
naked. someone rattle canned flat black on the faux tank. It is missing the two side panels and radiator fins. the front fender was chopped (and flat black) and it is missing the rear fender. It is now "parts in boxes" and engine on a coaster. I am currently redoing my OEM 78 so this one will wait.
Sadly, when I look at your pictures I get the "black x" at work. So I cannot see how your bike is finishing up.
tomk1960
#89
Post by tomk1960 »
I didn't post any new pictures this time. Once I take care of a few more little things, the bike will come off the lift and get rolled into the driveway for a proper warm-up, carb sync, and "burp" the cooling system. Then I'll take a couple more pictures of it pretty much all done. There are still a couple of electrical items to square away, but not too much is left. If all goes well, I should be able to put a few miles on it before riding season ends. It's good to finally have this one ready to see the light of day.
1978 Honda GL1000
#90
what happens is that our work computer "filters" out certain sites where pictures might be hosted. I cannot see youtube links here either
