Pedro!'s rebuilding projects
- Pedrotq
Re: Pedro!'s rebuilding projects
Bought a brake line flaring tool a while ago to make new lines for my GL-1000's.
The tool does DIN & SAE flaring
- The tool and a 7M roll of 3/16" brake line.
- 101_0665.JPG (374.87 KiB) Viewed 248 times
- Using the position bolt to align the correct depth of the line.
- 101_0668.JPG (120.72 KiB) Viewed 248 times
- Step one is to flare it out to a DIN fitting.
- 101_0669.JPG (175.75 KiB) Viewed 248 times
- By screwing this end right in.
- 101_0670.JPG (142.52 KiB) Viewed 248 times
- It gives the DIN flare.
- 101_0675.JPG (143.76 KiB) Viewed 248 times
Perth, Western Australia.
- Pedrotq
Continued
- Then we use the other end of the bolt to flare it out to an SAE fitting.
- 101_0671.JPG (121.59 KiB) Viewed 248 times
- As such.
- 101_0676.JPG (151.25 KiB) Viewed 248 times
- Slide the screw fitting on and she is ready for the bending process.
- 101_0673.JPG (82 KiB) Viewed 248 times
- This is the original contorted line with the screw fitting cut off as i need it that i have to copy.
- 101_0674.JPG (133.21 KiB) Viewed 248 times
- All done and ready to fit so i can flare out the other end in the correct place (yet to be determined).
- 101_0677.JPG (161.74 KiB) Viewed 248 times
- Pedrotq
I also fitted the rebuilt carbies using New insulator connector rubbers from Randakk's that are absolutely perfect!
Of course Dixie is keeping a sharp eye on me to make sure i do everything correctly as her life depends on the sidecar to transport her safely about.
- Dixie.
- 101_0678.JPG (87.18 KiB) Viewed 247 times
- 101_0679.JPG (72.59 KiB) Viewed 247 times
that tube bender is pure genius..
I like your flaring tool as well.
I have a snap on double flare tool that I bought 30+ years ago but you need a vise to clamp the bar in.
I like the handle on yours..which gives me an idea.
For some reason I have been dropped from the mailing list (probably waited too long to say anything due to awe) anyway this comment should get me back on the list. Glad to see you are still at it.
I've never seen that version of a double flaring tool. Where is the source of that one?
Cliff (74yrs )
- Pedrotq
G'day to All
That flaring tool i purchased from e-Bay for $45au
I managed to connect the throttle and choke cables, refit the air box and fit the two radiator fans, also fitted the front brake lines i got from e-bay, they came from a Valkyrie and fit perfectly, just had to make a bracket to mount the spliter.
The exhaust is just held in place by two bolts so i could route the brake line
Most of the time is spent looking for things that have been shifted several times since disassembly.
Happy and safe riding to All, Peter.
- My new squiggly sidecar brake line.
- 101_0680.JPG (318.63 KiB) Viewed 221 times
- The other end. I have not worked out the angle or height to bend and cut it before flaring.
- 101_0681.JPG (314.38 KiB) Viewed 221 times
- As she sits now.
- 101_0682.JPG (310.29 KiB) Viewed 221 times
- The big silver thing in the middle is the brake line bracket made from 2" flat Aluminium bar.
- 101_0683.JPG (242.72 KiB) Viewed 221 times
- BikeMaine
Great work on the brake lines Peter. I just want you to know that I'm stealing your bending tool idea.
Question, would copper tubing work/hold up for use as brake lines?
Kevin
1982 GL1100A
1982 GL1100A
Not regular copper but most auto parts stores now carry a copper/nickel line. Works well. Bends easy. Doesn't rust.BikeMaine wrote:Great work on the brake lines Peter. I just want you to know that I'm stealing your bending tool idea.
- BikeMaine
does it look like straight copper on the outside?. So it could be polished?robin1731 wrote:Not regular copper but most auto parts stores now carry a copper/nickel line. Works well. Bends easy. Doesn't rust.BikeMaine wrote:Great work on the brake lines Peter. I just want you to know that I'm stealing your bending tool idea.
Kevin
1982 GL1100A
1982 GL1100A
Bike looks kind of cool naked. I have a 1500 setting on my back patio that a friend gave me. Been wondering what to do with it, maybe a "streamliner"?
- Pedrotq
This is something that i want to do to a 15, just have to pick one up that has hit the deck and only has Tupperware damage.
- Naked 1500 in the GL-1000 styling.
- L_Side_GL1500.jpg (55.96 KiB) Viewed 190 times
This one is a bit "spare" but has some very clever ideas.
- 54fd8d2f927a18e6ffed1be6dffc2a1e.jpg (229.21 KiB) Viewed 183 times
Yes, I've done some fuel lines with it and just a little polishing makes them look very nice.BikeMaine wrote:does it look like straight copper on the outside?. So it could be polished?robin1731 wrote:Not regular copper but most auto parts stores now carry a copper/nickel line. Works well. Bends easy. Doesn't rust.BikeMaine wrote:Great work on the brake lines Peter. I just want you to know that I'm stealing your bending tool idea.
- Pedrotq
G'day to All
I had to re-design the front brake line bracket that i made as it interfered with the speedo cable and fairing bracket on full extremities.
- Bracket Mkii.
- 101_0685.JPG (335.93 KiB) Viewed 158 times
- Flip side.
- 101_0686.JPG (323.9 KiB) Viewed 158 times
- Crush tubes through both the plastic and new bracket.
- 101_0687.JPG (245.6 KiB) Viewed 158 times
- Ah, that's better.
- 101_0688.JPG (224.75 KiB) Viewed 158 times
- 31 Replies
- 1966 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 36 Replies
- 1123 Views
Last post by Fred Camper
