A CX500 for Christmas
Re: A CX500 for Christmas
Today is Thursday, on Sunday evening I ordered my custom length stainless brake lines from a company in Canada, they arrived in this mornings mail and are now installed. Barely four days, Amazing. This is probably the fourth set I have ordered from them and have always been pleased.
Put antifreeze in the radiator today only to find it has a small leak. I may just leave it alone till I get it running to be sure none of the water pipe joints leak. Don't want to have to take it apart twice.
Painted rear fender goes on tomorrow. I had ordered an under the fender tail light but it turned out to be too wide for the fender so I will have to go to plan B (what ever that turns out to be). Also made some headway with the exhaust system, looks like it will work. (Pictures later).
- delling3
Really like where this is going Easter. Fender paint issue aside, really looking nice. Will this be a "keeper" or are you planning to "flip".
Always liked the "baby Guzzi".
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
Company is called 'Apex' .... they do good work ....Easter wrote:Today is Thursday, on Sunday evening I ordered my custom length stainless brake lines from a company in Canada, they arrived in this mornings mail and are now installed. Barely four days, Amazing. This is probably the fourth set I have ordered from them and have always been pleased.
Gord (not affiliated) Jones
if I recall, I had a small antifreeze leak on my cx500c... it turned out to be the mechanical seal... a real PITA to change
Unfortunately this leak appears to be coming from the fins. I do have another radiator but not sure if it is any better. I think I selected this one to clean up because it looks better.
Regarding keeping it, we shall see after I ride it a bit. And speaking of Guzzies, there is a sharp '73 for sale in the Houston Craigs List. Now if I could sell four or five bikes, maybe...
I am at the stage where things move along in sync with package delivery. Today was a good day with four packages allowing me to move forward with the exhaust and throttle controls. I also got a battery.
Copper rings in today's mail allowed me to bolt up the exhaust in final position. Everything fits good. Sportster pipes may not be the best choice for this build but I have them and they are in perfect condition. I was able to use sections of the Sportster plumbing to tie them into the stock headers. Unfortunately there is some discoloration from heat but since they are chrome I hope they will stay looking better than conventional exhaust pipe adapters.
I thought installing throttle cables on the GL1000 was difficult until I spent two hours trying to connect the new cables to the CX carbs. Persistence and scraped knuckles eventually won out.
A new master cylinder was also installed and mostly bled. Hope to get the last of the bubbles out tomorrow. I might have a leak at one of the caliper piston seals. Hopefully it will settle in.
You will notice in the photos that I have an aluminum box beneath the seat. That will house the battery and most of the electronics. Installing it will require drilling a bunch of holes ranging from one inch down. I just hope I can get them all in the right place. I plan to install the ignition on the side of this box as well.
I spent a couple of weeks visiting family (Houston and the great state of Michigan) and am now back working my way through the wiring. I disassembled the stock harness and modified as required for different components and the relocation of the ignition and fuse panel. A real brain teaser for this old geaser!
The tail light assembly is a combination of five very bright LEDs mounted on an aluminum panel. I was able to use the stock holes in the rear fender to mount. They are concealed when the seat is mounted. Because the LEDs are single "filament" a different LED is required for each function. The tail light/running light is in the center while brake lights are on either side with turn indicators on the outside. The turn indicators on the rear are augmented with signals on the ends of the handle bar. the most difficult part of this process was soldering these near microscopic wires to bullet connectors. Standard color coding was maintained.
It lives
The starter was dragging but seems to have cleared up. Turns over good, starts good and seems to run fine. I have only run it a few minutes on an auxiliary gas tank but it didn't seem to smoke and responded well to the throttle.
Radiator will definitely have to come off for repair or replacement. I have another one but am not sure of its condition. I have not checked the charging system yet so don't know if it is charging correctly. But we are close.
I just knew things were going too well! Water leaks... plastic drain plug on radiator doesn't seal very well. No problem, all it needed was a new rubber seal. Radiator leak, minor but never the less, a leak. I found my spare radiator, gave it a bath in acid and after plugging all the outlets, gave it a shot of air. Leaks like a sieve from about a half dozen spots. Sooo, what to do with the one I originally installed? Radiator stop leak?
Radiator shop? Well, we shall think on it some more.
But the worst water leak (I think) is coming from the bleed hole on the water pump cover at the back of the engine. What does it mean? Probably means the seals are bad and the engine has to come out of the bike! When this happens on a GL it is usually oil seeping out. Replacing the water pump and or seals is not fun but manageable in a couple of hours. This seems much more involved.
On a positive note, the bike seems to run good so it seems salvageable.
- scootsx2
Replacing the CX500 water pump involves pulling the engine which is simple if you have a transmission jack or similar to roll underneath the lump.
Regarding the radiator, don't use stop-leak. It's a nasty kludge. Take the radiator to a competent shop for repairs. On my '82 CX500 police trike I had to have the radiator recored - now it's like new.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
THAT is one gorgeous radiator! I plan to spend a day soon straightening the fins on my GL1000 radiator. I plan t mask off the business area of it and just paint the shell and tanks. Hope to avoid a recore, and don't want to cut the heat transfer with a paint layer.scootsx2 wrote:Replacing the CX500 water pump involves pulling the engine which is simple if you have a transmission jack or similar to roll underneath the lump.
BTW, pulling the GL1000 engine was facilitated by adding doubled 2x4s to a Harbor Freight furniture dolly and strapping the motor to that.
the leak is probably the mechanical seal. At least on my cx500c, you have to pull off the back cover and use a bolt and nut to press the seal and housing back into the cover
After doing considerable research on the CX500 website and related posts on facebook and wiki, I determined that it is feasible and practical to service the water pump with the engine in the frame. The only issue is whether the oil seal is good or not. If bad, the engine has to come out to remove the entire back cover. There is a fairly simple process for replacing the guts of the mechanical seal without the necessity of removing the cup (or housing) of the mechanical seal which must be pressed out from the inside (as does the oil seal).
Unfortunately my problem is much more severe!! The impeller end of the cam snapped off leaving the water pump inoperable. (this explains why it was difficult to turn the motor over until it suddenly broke free) Eventually I will have no option but to tear the engine down to replace the cam and such other components as required. In the interim I can't resist the "opportunity" to explore the possibility of an external electric water pump. I have selected one and have it on order so we shall see how that works out. Cams alone are running over $100 used plus the other seals and gaskets and probably cam chain and tenshioner etc. will probably cost around $350 total. The automotive electric water pump is less than $50 and should fit on the side of the engine where the chrome water pipe resides.
- Sugs
Ewww...that's a bit of a bummer.
_______________________
'79 Honda GL1000 Goldwing
- delling3
Fugly . . . sorry to see that.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
