Swissitalian 1200 custom bike
Re: Swissitalian 1200 custom bike
I know the function of the bottle. Without recovery there will be about 5% air space in the radiator with cold engine. And with hot engine actually no restriction. Isn’t? I will try it and keep the temperature under control.
But if you start with the radiator full, which you should, then when it warms up and pushes fluid out there won't be any to go back in. It won't be very efficient. Then if it get even warmer and pushed more fluid out you'll have even less coolant. There are plenty of after market bottles you could use that would look good. Always something to go with the build you are doing. Or make one.
I already have the red camping bottle of my daughter on it. I can not believe that the radiator is getting always emptier . When the engine is cold, there is on the top of the radiator an air cushion because no water could flow back. When the engine its getting warmer, the water pushes the air out until the radiator is full again and it only flows out if the water gets warmer than run befor. Or is this a consideration error?
The radiator is designed for 1200 pounds maximum weight. My bike is driven with a maximum of 750 pounds and has even more wind for cooling. I think it should work, otherwise a bottle is quickly mounted again.
Mine is completely naked and what Robin says will happen. Just a few hot surges of running the engine hard will pull the volume of coolant down. The radiator gives the appearance of quite a bit of volume, but you have to remember that once the top chamber of the radiator is emptied out, it is only the coolant inside each tube- —not very much. It doesn’t need to come down very much to be the level of the upper discharge tube on the motor.
If you think about the extra time it takes to fill a radiator from the coolant trying to go down, so the air can go up, you can probably envision a point where the pump will starve and start mixing air. At that point it becomes an issue of the radiator cap and pressure. If the pressure is above cap pressure it’s going to vent. If the top of the radiator was all air, it would be fine, but if it’s bubbly or all coolant trying to work down past the air in the cooling fin tubes, some will get expelled. If some of the air is steam, it will slowly remove some of the liquid in the form of steam. If it gets to certain point where it’s bubbly at the pump, what happens then?
I have a 1200 black with a larger volume 1100 radiator and it requires a reservoir. I’ve seen others who run without them, but mine eventually gets low enough to begin overheating.
Thanks for the explanation. I'll get first everything running well with coolant reservoir and the new motoscope pro. After that I will try without, see what happens and inform.
Are you fitting any bodywork to it?DonGold wrote:Thanks for the explanation. I'll get first everything running well with coolant reservoir and the new motoscope pro. After that I will try without, see what happens and inform.
Sorry, I do not understand the question. Bodywork in relation to the reservoir?
I once said that I want to unlink the brake because I am only a front braker and brake with only one disk it’s to weak. If someone plans to do the same, unfortunately it did not work with less money. The front brake calipers have different pistons, the master cylinder is too weak for two front discs and the rear brake cylinder is too strong for only the rear brake. The rear wheel is blocking too fast. In the future I will change the front end and then record this goal again.
False tank, side covers, front n rear mudguardUK_Andy wrote:Are you fitting any bodywork to it?DonGold wrote:Thanks for the explanation. I'll get first everything running well with coolant reservoir and the new motoscope pro. After that I will try without, see what happens and inform.
No, no false tank, cover or fender. Today I modified the exhaust, but I'm not satisfied. I have seen, that a lot of custum wings stock mufflers from other biks ride. Do they fit without any adjustments? Which one?
quite a few folks use Harley slip on mufflers..which are easy to find. I think the mounting tab may have to be moved but I'm not 100% sure.DonGold wrote:No, no false tank, cover or fender. Today I modified the exhaust, but I'm not satisfied. I have seen, that a lot of custum wings stock mufflers from other biks ride. Do they fit without any adjustments? Which one?
- desertrefugee
Pre-cat Sportster mufflers are a perfect fit. Mine are on with no welding - just some shims, clamps and easily fabbed hangers. No leaks, looks great, sounds great. That's why they're a favorite choice.
Thanks. Do you have a picture of your bike with the Sportster mufflers? I have two mufflers of mine Sportster, but are the cat one. I look on ebay für the others.
I fitted these on mine. Little bit of welding but they fit very well
https://www.ebay.co.uk/itm/38-51mm-Univ ... Sw0UdXrV~H
Andy, I like the pipe shape. I do not understand the measurement. The text says, Pipe length 44cm and the photo is measured with 50cm without cap. Do you have a picture of your motorcycle with this pipe?
- 7 Replies
- 648 Views
Last post by BikeMaine
