GSXR 600 ITB/EFI project.
Re: GSXR 600 ITB/EFI project.
Well, I could do the hole saw thing. I did manage to find some carb boots that I can use with either intakes on the throttles. I found an angled carb "socket" for a Rotax engine with an angle on it that should fit the GL1000 runners and the throttle bodies. What I think I will do is just order 1 cheap knock off (10 bucks) and see how that works/looks. if not, then I will go ahead and figure out if I want to use the 1200 runners and simply order the straight boots to adapt them. I know I could use a hole saw, but eventually I would be buying new boots anyway as these current ones are rock hard and cracked a bit on the 1200 runners I got, and I wouldn't trust them.
