Hello GoldWing owners, I just bought 78, what I fine machine.
I changed the timing belts.
Followed all the instructions and u tube videos I could find, all seems fine but as I rotate the motor the belts get loose at one point then tighten back up.
Is that normal??
Thanks in advance for any advice
Mike
Bakersfield Ca
Timing Belts
Timing Belts
Mike
Bakersfield
78 GL1000 Current Bike
2004 R1150R Sold
2000 Sportster Sold
1994 FXR Sold (should have kept)
84 1200 Aspencade Sold
80 1100 Standard (should have kept)
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
Re: Timing Belts
when the crank to cam pulley side is tight, there can be a slight amount of slack on the other side. The idler is spring loaded, and sets the proper tension, when the other side is tight,
Re: Timing Belts
Re: Timing Belts
I appreciate the replies, I really think I have it right but trying to convince myself a little more.
I cant see how not to have some slack in the non tensioner side for a brief moment while the engine spins over and the cams load an un load from valve spring tension.
Also I understand when things heat up they also tighten up, the drive belt on Harleys I have had tightened up after riding for a while.
Mike
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
- Angeltrumpettech
- Zinc Member
Re: Timing Belts
i had the same trouble with one of the belts, turning the crank 360, timing mark facing in, did the trick for me on the tension.
Growth pains hurt but the end result is a grown man.
omnia causa fiunt
1975 GL 1000
1979 GL 1000
2014 Honda CTX
1977 Yamaha TT500
omnia causa fiunt
1975 GL 1000
1979 GL 1000
2014 Honda CTX
1977 Yamaha TT500
- RB
Re: Timing Belts
Also the cams put tension on the turning of the crank..so it could be that too.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- BlueThunder
Re: Timing Belts
Follow Octane's method... it works and makes it painless.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- 4 Replies
- 2630 Views
Last post by Whiskerfish
- 2 Replies
- 2454 Views
- 14 Replies
- 13789 Views
Last post by lipsee
- 39 Replies
- 7430 Views
Last post by Rat
- 5 Replies
- 3005 Views
Last post by jdvorchak
