'72 CB350 cafe "resto-mod"
- Norbert R
Re: '72 CB350 cafe "resto-mod"
I have a '70 CB450 that belongs to a friend which I've stripped as the crank floats left to right by about 2mm, a PO rebuilt this motor and messed up a couple of things. I think they put the crank back without some thrust washers and that's why it floats side to side. Not having dissasembled it it the first place, not sure if it is salvageable even if I can get the missing washers because I don't have the original factory measurements for the throws any more.
Pity, cos the bike itself is in really nice condition.
- luludog
The CB450's are very cool and keep increasing in value.
As an option; you might think about getting a used crankshaft. There's a few on eBay and it wouldn't hurt to try the Honda Twins site.
Did a little research. The crankshaft assembly is the same as these years & models. Good luck!
Part Number: 13000-292-677
CB450 K1 1968 450cc Street
CB450 K2 1969 450cc Street
CB450 K3 1970 450cc Street
CB450 K4 1971 450cc Street
CB450 K5 1972 450cc Street
CB450 K6 1973 450cc Street
CL450 1967 450cc Dual Sport
CL450 K2 1969 450cc Dual Sport
CL450 K3 1970 450cc Dual Sport
CL450 K4 1971 450cc Dual Sport
CL450 K5 1972 450cc Dual Sport
-Ray
- Norbert R
Thanks for the info Ray!
I've signed up with the Honda Twins forum, but haven't asked the questions there yet.
Unfortunately getting the cranks on eBay shipped to SA will be impossibly expensive.
- luludog
Went a different route with the oil filter. The stock unit is a centrifugal type.
Was never a big fan, so with some research; found this jewel!
It did require some minor modifications.
A hole had to be drilled in the side cover.
The stock filter had to be cut or machined down to 22mm. Makes room for the new filter, and acts as a spacer for the gears, washers and nut.
Here's a shot of it installed. Will probably polish it after the first oil change.
Cleaned & lubed the advance, installed the points, and wired them in.
-Ray
Nice, an actual filter. That should be much better.
- Norbert R
Much better than the centifugal one IMO. Will look nice if you polish it after 1st oil change.
- luludog
Thanks guys
Some updates
Did the bling thing on the oil filter (thanks for the hint
Cleaned up the swingarm
Rebuilt the rear brake caliper & new wheel bearings.
Some updates
-Ray
- Hanslehoff
That is looking awesome, gonna be a fun little bike when you're done
1975 Cafe Wing
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=56574
- wingrider
Awesome Ray!
- luludog
Thanks guys!
Lots of yard work, so not much happening in the shop.
Found these
On the bike
Won't be using the kick starter (for now. needs to be extended, more fab work)
Instead of leaving the shaft bare; made a couple of covers. Probably go with the right one.
Getting closer to having a hydraulic clutch
Found these
On the bike
-Ray
Looking super!
- Norbert R
Ray those finned cam covers are THE BUSINESS !!
- luludog
Thanks, really enjoying this project
Got a tip from one of the members on the VJMOG site. Contacted the owner, we agreed on a price, two days later they were in the mailbox. Very, very fortunate to have them!Norbert R wrote:Ray those finned cam covers are THE BUSINESS !!
-Ray
- Norbert R
Well you've certainly done them justice, motor looks fabulous with them on and all polished
