click here:
viewtopic.php?t=79374#p833813
Carburetor Removal, GL1100
macka
Re: Carburetor Removal, GL1100
#31
Post by macka »
seafoam or atf, I suppose you could run them together, but have never heard of anyone doing this.
1981 interstate 1100 not so stock
calif wingnut
Re:
#32
Post by calif wingnut »
78AZWing wrote:Can the 1000 carb pack be removed the same way that Roady details for the 1100?
Mine is only running on the 1/3 carbs at the moment and with the points and coils firing front cylinders then rear cylinders the problem is most likely the passages in the 2/4 carbs are gummed up.
And have been reading all Randakks' articles on the 1000. Great stuff!
Thanks for the answers.
Yes, but remove the air cut off valve with a long 22" phillip screwdriver, as it will impede the removal process.
Sceadufaex
Lead Member
Lead Member
#33
Post by Sceadufaex »
This is awesome info. This might sound stupid. But should I even attempt to rebuild my carbs on my own. I'm pretty good at doing things with a diagram. Especially with you tube walk through. But I have a stuck float valve, and the carbs have never been removed on my 1980 gl1100. What do you think guys. I'd appreciate any help here.
#34
We all had zero experience at one point. If you have the space, the time, the attention to detail and the ability to focus then yes you can probably do a decent job. My first rack took me about 12 hours straight only taking breaks to get a drink and use the rest room. I was very meticulous and they came out prefect. Now many racks later and I can generally do them in about half that time. If you try to go fast and take shortcuts then you are wasting your time and will do it over.
#35
Also, along with the recommended Randakk rebuild kits order his Video. I believe it is made for the 1000 carbs but still good for a first timer to watch. It will show some good techniques.
Sceadufaex
Lead Member
Lead Member
#36
Thanks guys. I think I can do this. Man these sites are so helpful!
#37
Don't forget after the rebuild you will need to synchronize them.
Sceadufaex
Lead Member
Lead Member
#38
Thanks for all the advice. I wil definitely have them synchronized.
#39
And clean out the fuel system ... tank to pump ... and replace the hoses with 1/4 inch fuel line and new clamps.
#40
Pictures restored in first post.
#41
Good deal. How have you been Steve?
#42
I'm doing pretty good. How you been Richard? I see you're keeping busy.
