Finished!!!!! rethinking a 1200
Re: rethinking a 1200
Looks like a patch that will keep on working.
- thumbsupd.png (35.52 KiB) Viewed 262 times
my welding skills or not so good.... I don't lay a bead, I make a splatter. the place was dented in and so couldn't just fill the hole. So I rounded off the patch and welded it over. Then painted with grey header paint
well five months have gone.... there were rides to ride to... and when at home too hot and humid to do anything
Saturday primed several of the pieces. One thing about primer is it makes the rough spots and blemishes stand out. So many of these pieces will also get some sandable primer/filler and some work. Anything you can see or feel now will be there later.
of course, I could just leave the bike primer grey
Depending on the size of the blemish you may want to use a glazing compound cause sandable filler primer can only do so much.
mostly it is a feathering problem. Some of the OEM parts had more than one layer of paint and then I painted it a couple of times
- duke182
Looking good
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
I have a 12 x 16 shed I store all the outside equipment in. I recently added two shop lights and a "attic fan" mounted in one of the windows. as it is some distance fro the house and I did not want to run both the 5 hp compressor and the lights/fan off the same circuit. I have a deep cycle marine battery in the shed and an inverter. I run the lights and fan off that while painting, and then run a charger overnight to the battery. the fan really keeps the fumes out of the work area
the only down side is I have to take most of the stuff out of the shed to paint there....
- duke182
Still better than doing it in the open.
As long as you go get a resperator.
1984 1200 standard
vote in my poll
1984 1200 standard
vote in my poll
- wingrider
A few year back, I used the garden shed to paint my little hotrod John Deere 110 garden tractor. The wife was very understanding, but always seems to bring it up when I think about doing something else. It is a great way to have a paint booth!rcmatt007 wrote:...snip....
a respirator is always an absolute must. the set up of the shed really only allows me to do 4-5 pieces at a time, so I go in and paint, out fairly fast, and automotive paint flashes rather fast, so I can let it continue venting and then exchange the parts. Overnight I recharge the battery. Will get up some pics of the set up this weekend
sanded it down, then shot it with a sandable primer which I now I have sanded nearly all off, and reshot with the urethane primer. Then some 1000 wet sanding (smooth as a babys' bottom!) and I think I am ready for the base coat. Hopefully not too cold or raining on Saturday and will get started with the real paint!
Progress is a good thing.
No drips, no runs, no errors, looks good.
- wingrider
Lookin' good! Keep up the good work!
- 6 Replies
- 502 Views
Last post by robin1731
- 27 Replies
- 1667 Views
- 6 Replies
- 734 Views
Last post by duke182
- 13 Replies
- 1003 Views
- 6 Replies
- 445 Views
Last post by Placerville
