How To Clean and Repair Your Fuel Tank Sending Unit
Paul Narramore
Re: How To Clean and Repair Your Fuel Tank Sending Unit
Post by Paul Narramore »
I have my sender unit out and am about to begin soaking it in White Vinegar as I have been unable to locate any Evapo-rust here. Although it doesn't work, my gauge is pretty clean with almost no corrosion, unlike those shown here. Lets see if cleaning gets it going again.
Present bikes -
BMW R100/7
1989 BMW R100GS-Paris Dakar
MZ ETZ250 Trials
1977 Honda GL1000 GoldWing
salukispeed
Post by salukispeed »
A very nice write up for sure. Well done.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
77Gowing
Post by 77Gowing »
Great write up!
Reg Phosphoric Acid: There's a product called Milkstone remover that is PA and is used for cleaning dairy farm equipment.
You can get it at Tractor Supply for about $12/gallon. I mix mine at ten parts water to one part PA and it is a wonderful rust remover. It's also biodegradeable. I left the rear wheel spline hub in it for three days after forgetting about it and found that it does indeed slowly react to cast iron, I have the replacement part from Cyborg to prove it....Duh? Other than this one problem using PA, I've cleaned lots of flash rusted chrome with it. I use a fifteen gallon kitchen trash can with a lid as my vat of rust remover. I've been using the same batch for two years and it's still active, though I need it down and clean out the sediment. It looks nasty but it works.
Fer whut it's worth fellas.
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold :crying)
2014 Yamaha 950 V Star (sold)
Paul Narramore
Two days soaking in a small cup of wine vinegar and after a quick rub down with a cloth, it looks like new. A tweak to the tiny screw to ensure the arm rubs along the fine wires (I don't think it did before) and I'm just waiting for the special petrol-resistant sealant to arrive in the post.
Present bikes -
BMW R100/7
MZ ETZ250 Trials
Paul Narramore
OK, it's been a little while now. I cleaned up the sender unit, it really wasn't that rusty, and tested it using my multimeter. All seemed OK. Replaced it, connected everything up and.............the fuel gauge still swings over to 'full' even though it's a half full tank. I have removed the fuel gauge but how (using my multimeter) can I check it? I don't want to buy another unless I really need to and if this one's OK and the fault lies elsewhere.
Present bikes -
BMW R100/7
MZ ETZ250 Trials
There is a 7volt regulator mounted on the left side of the shelter frame that may not be working correctly.
Its only purpose is to provide 7volts positive to the fuel gauge and the engine coolant temperature gauge.
Check its output voltage. Overvoltage may be as simple as an insufficient ground path connection to the 7volt regulator.
If the temperature gauge is also pegging into the hot zone, although the engine is cold, that is an indicator that the 7volt regulator isn't doing its job.
Been there-Done that!
Cliff ;) )
Paul Narramore
I do know for sure that the temperature gauge DOES work as it should. However I will check the 7v supply.
Present bikes -
BMW R100/7
MZ ETZ250 Trials
