GL1100 carbs on a GL1000?
katmol
Post by katmol »
I've heard that GL1100 carbs on a GL1000 work very well. Is that true?
Old Naked Wings and SOHC 750's
Re: GL1100 carbs on a GL1000?
Yes, they work. I have a set on mine. Only because I didn't have a good set of 1000 carbs at the time. Top end performance will suffer a bit as the 1100 carbs are smaller.
RB
Post by RB »
Yep, but more expensive to rebuild, and you won't get top performance but they do work..
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
TheWheel
Post by TheWheel »
Randak has a long blog post on this subject:
http://www.randakksblog.com/early-vs-la ... b-specs-2/
Don R
Post by Don R »
My 79 has 83 carbs on it, it runs OK but seems lean at low rpm when cold. it chugs if I don't warm it up long enough. I'd like to put it back to stock.
J Wright
Post by J Wright »
so the 1100 carbs are smaller than the 1000? would you get more performance out of putting 1000 carbs on an 1100 then?
J Wright wrote:so the 1100 carbs are smaller than the 1000? would you get more performance out of putting 1000 carbs on an 1100 then?
Simply put, no. The carbs are 'matched' to the engine and it's characteristics, especially the cams. Other factors, such as gearing, also make a difference. Putting 1000 carbs and cams will change the performance of the 1100,from what I've read. There are a couple of people here who've done that...
katmol
Post by katmol »
Thanks for all the info. I think I'll just keep the stock carbs on my '76.
cmyoch
Post by cmyoch »
My 1000 has performed well with 1100 carbs for several years now. The bike came that way and I had the same concerns. If I can get my hands on a good 1000 rack for a reasonable cost, I'll convert back for the sake that everything is matched. Otherwise, I'll keep riding the way it is.
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
Easter
Post by Easter »
I have an 1100 that I resurrected (certainly not restored) and after messing with the stock carbs for a while, I switched to a set of GL1000 carbs fresh from the box (rebuilt by Pistol Pete) for another project. The bike runs well but I don't think it has the get up that my other 1100's have with stock carbs. I will switch back to the stock carbs as soon as I get the 1000 project I am working on ready to run.
83 GL in process :IDTS:
I like 1100 carbs on a 1000 ..... better cold starts especially.
I don't miss the little bit at the top end ...... :wheelchair crossy.gif :wheelchair
Easter
Post by Easter »
RAT wrote:I like 1100 carbs on a 1000 ..... better cold starts especially.
Yes, the 1000's usually get a squirt of starter fluid to save the battery, the 1100's usually kick off on the first rotation.
