I'm a newbie
mbraun
I'm a newbie
Many years ago I had a Kawasaki 1100 Spectre. This is an air cooled shaft drive bike. I liked it but kids came and the bike went. Now, kids are gone and a mechanic friend of mine keeps telling me to buy a GL1100. I have looked at the naked Goldwing site many time thinking about this project. I like the wheels on the 83 the best so today I purchased an 83 gl1100. It has all of the body work off of it and has not been run in years. I am sure it needs the brakes rebuilt top to bottom and gas tank cleaned. It is a 37K miles bike. The old gentleman (74) I bought it from seemed like a great guy. We chatted for about 3 hours. He has all of the parts I need except a seat. His house had 3 rooms of Goldwing parts, so I maybe back LOL. He is throwing in extras as well as a Honda manual. He is getting out of motorcycles due to his age and health. Here is a pic of the new project. I am planning a simple clean naked build. I am a better than average car mechanic but wish me luck as this will be my first motorcycle build.
PS if you have a seat for sale, let me know. (seat found)
- chewy999
Re: I'm a newbie
Welcome to the forum from the UK, you have found the best forum for help and advice for GL's. You have made a good start, apart from a seat, but surprised me the seller is getting out of bikes because he's 74. I'm 55 and considered a youngster here, amongst other things!
Any questions ask away and someone will be able to help. Let the fun begin.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Re: I'm a newbie
Welcome to NGW ... like most of the 83 especially the wheels. The 83 does have linked brakes. Luck on your project.
mbraun
Re: I'm a newbie
Thanks for the info.
I just learned about linked brakes yesterday from the old gentlemen that sold me the bike. I never knew about it before that.
I also learned that the 83 has a hydraulic anti dive system on the front forks. I thought that was cool.
Kriss
- gearhead4207
- My Album: http://s1366.photobucket.com/user/gearh ... %20Uploads
Re: I'm a newbie
83 gl 1100 i stripped gone but not forgotton!
82gl1100sold
black betty
81 gl1100sold
78 gl1000 bagger mongrel sold miss you my friend
87 aspencade sold
84 aspencade f4-b build :mrgreen:back
87aspy stripping for road warrior
82gl1100sold
81 gl1100sold
87 aspencade sold
Re: I'm a newbie
Welcome, I too have an '83 Aspencade (along with several other old Wings) and agree with you about the wheels. In fact bought a set to use on my '80 Model. Linked brakes are not a problem but can be eliminated easily if you choose. Start your project by becoming familiar with the Shop Talk section of this sight. Most of your questions will be covered there. Good luck and have fun.
Re: I'm a newbie
Welcome to the 'Wingdom.
74 doesn't sound too old ......
Gord (74 in November) Jones
'13 Honda NC700sa … TNG
- zman
Re: I'm a newbie
Welcome to the forum, I was new to GL`s when I joined , I knew other bikes very well , mostly I thought why did they put the clutch,generator and ignition in a location not easily accessed, why an interference motor , why is the water pump buried in the motor instead of mounted to the outside or easily accessed location.
I suppose they had good reasons but I might have picked the Voyager or Venture instead
I don't really regret buying it though , get it right and they are rock solid and a pleasure to ride and own.
1980 1100 Interstate, 1978 GL1000
miltoncaniff
Re: I'm a newbie
Welcome from Iowa! We need more people from the Great Midwest to join! Thanks for doing your part and enjoy the build!
John
John
1977 GL1000/1976 GL1000
1975 GL1000/1975 GL1000 (Parts Bike)
2002 FLHRCI/1993 ZR750C3 Zephyr
1982 GS750EZ/1978 GS550
1978 KZ1000A2/1978 KZ1000A2 (frame only)
1980 KZ650F1/1979 KZ650B3
1979 KZ650C3/1981 KZ550A1
1977 KZ400A1 Deluxe/1979 KZ400B2
1982 KZ250D2/1980 KZ750E w/parts bike
This is not MY circus and You are not my monkeys!
mbraun
Re: I'm a newbie
Well, I have been working on it as I have time. I found a motorcycle salvage yard about 30 minutes from my house and scored some needed parts. I got a seat in really nice shape, a front turn signal, a right side cover with all 3 attachment points, a set of new handle grips the guts and ring to my empty headlight bucket and some much needed nuts and bolts. The rear fender has been sanded and primed. Flat black on the underside. The top has 2 coats of primer and 3 coats of Cobalt Blue metal flake on it. I have polished the rear light assemble and shocks along with the rear half of the exhaust pipe so that I could install the rear half. Looks good so far. I have filled in the holes for the small GL1100 emblem on both side covers, did 2 coats of primer and the inside of the covers in flat black. Tonight's project is 3 coat of the Cobalt blue.
mbraun
Re: I'm a newbie
More work getting done. The head light mounting ears that I have were "modified" by someone. The tabs where the turn signals mount had been cut off. So a bit of 1/4 x 1/2 bar stock, a cut off wheel, bench grinder and a gas welder fixed that. Then a 4mm hole and tap and it was good to go. Polished the headlight assembly and the mounting ears, removed the front wheel and each fork arm, installed the head light mounting ears and but the forks and front wheel back on. Then moved some wires around and installed the headlight bucket and front turn signals. The front "valence" bracket that was on the bike held a semi circular black piece of plastic so I removed it. In the box of parts was a Honda front "valence" so I modified that bracket and mounted it to the front of the bike between the turn signals. Now waiting on a bunch of part that I ordered to start the brake system rebuild.
- duke182
Re: I'm a newbie
Welcome to the club
Looks like a good start.
Just remember, we like pictures.
And you can get answers for almost anything here, and sometimes they're good answers. So ask away
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- 82aspy
Re: I'm a newbie
+1duke182 wrote:Welcome to the club
ngw quotes
- \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
ngw quotes
- nakedall
Re: I'm a newbie
Welcome, this is a great bunch here. Anything you need to know is here!
pat
84 standard black
81-83 standard
79 complete needs work
78 a mess now parts bike
84 standard black
81-83 standard
