75 only firing on the right cylinders
Irishman1
Post by Irishman1 »
What do you think is going on? The right two jugs are firing but the left side doesn't seem to be firing. I have spark on both sides but it doesn't fire when I spray starter fluid into the left side??? I'm going to pull the carbs tonite anyway because the old filter looked like it was full of coffee grounds
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
chewy999
Re: 75 only firing on the right cylinders
Post by chewy999 »
Irishman1 wrote:I'm going to pull the carbs tonite anyway because the old filter looked like it was full of coffee grounds
Sounds like you've answered your own question. Even the filter will let bits through and sounds like your carbs will need cleaning. What does the inside of your tank look like for rust?
anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Irishman1
Post by Irishman1 »
The tank on this one is awesomely clean. The bowls have the coffe grounds in them too! Cleaning carbs now!
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
chewy999
Post by chewy999 »
Sure your not cleaning your coffee maker? :lol:
Hope you find the source of your 'coffee grounds'.
anim-cheers1
Previous Rides,
Current bikes
chewy999
Post by chewy999 »
If your tank is clean but your filter isn't, that points to either dirty pick up tubes, fuel line breaking down internally, or contaminated fuel! Is there debris in all the bowls? Just 'speaking' out loud.
anim-cheers1
Previous Rides,
Current bikes
salukispeed
Post by salukispeed »
I may be missing something but you said you have spark on both sides and if you did not get any change with the addition of starting fluid for the left side you likely need to dig deeper. The plugs could be fouled for some reason but swapping left for right would confirm that. Possibly a compression test and then maybe Pop the valve cover off and confirm that all is well. timing belt??
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
Irishman1
Post by Irishman1 »
Yes, that's thd weird part. I swapped coils thinking it was bad coils even though it was just both plugs on the same side. It still does it with the different coils. Compression is 155 all around. But here's what the carbs look like
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
Post by Irishman1 »
I should say that last week this bike ran so smooth in small amounts, was just about to take her for a shakedown ride after restoring her up to the carbs, it was running so nice I didn't want to disturb them yet
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
Irishman1
Post by Irishman1 »
This is the other red 75 in the back here
In the garage:
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
