dash bulb
- Zinc Member
Re: dash bulb
Sorry it for a 75 gl1000!
Re: dash bulb
I have seen it but I can not remember where? Did you try any searches?
- Old Fogey
Re: dash bulb
They are just standard BA9s
- ke4cap
Re: dash bulb
Sylvania #1445 is what is mentioned on Randakk's site. I used them. They work!
Smiz
___________________________________
1977 GL1000
1973 CT90
Once upon a time, but no longer: 1998 GL1500, 1974 Kaw 900Z1, 1971 SL100, 1972 CB750, 1972 CB500, 1966 150 Dream
1977 GL1000
1973 CT90
- CRAFTMAN6001
Re: dash bulb
mickeyc wrote:Does anyone have a cross over for the dash bulbs?
https://www.superbrightleds.com/moreinf ... ower/2077/
- cool white
- leds.jpg (28.25 KiB) Viewed 379 times
1978 GL1000 01/77 GL1E-4011648 Factory /
GL1E-4115753
GL1E-4055247
VETTER PACKAGE 21-2523571 36-240270
Vetter 13-108977 Lowers
GL1E-4115753
GL1E-4055247
- gregforesi
Re: dash bulb
BA9 conventional bulbs or BA9-5SMD for the LED's. I couldn't get the LED's to work in the neutral or turn indicator circuits (probably because other things use those circuits). The high beam indicator and oil light aren't on enough to bother with.
The BA9 incandescent bulbs are rated at 7 watts and the LED's are about a 1 watt draw so your stator will see some power savings as well.
2006 GL1800 (Brutus Maximus)
- CRAFTMAN6001
Re: dash bulb
I hear you there. I should have been more detailed to what bulbs I replaced. Just the gauges bulbs. x5. I have the signal lamps (dash) to do yet. Guess I could use the extra bulbs there. I have a handful of them. Super Bright LEDs will do a refund and either put it to getting what I want. But I'm not one to play with shipping and refunds. I'll use them.gregforesi wrote:BA9 conventional bulbs or BA9-5SMD for the LED's. I couldn't get the LED's to work in the neutral or turn indicator circuits (probably because other things use those circuits). The high beam indicator and oil light aren't on enough to bother with.
GL1E-4115753
GL1E-4055247
GL1E-4115753
GL1E-4055247
Re: dash bulb
I use LEDS from superbright. GET THE ONES THAT HAVE THE WIDEST ANGLE (which are usually the brightest) LED lights can be very unidirectional which don't work well in the gauges
- 8 Replies
- 240 Views
Last post by Fred Camper
- 5 Replies
- 241 Views
Last post by SnoBrdr
- 14 Replies
- 454 Views
Last post by jdvorchak
- 9 Replies
- 565 Views
Last post by Sidecar Bob
- 17 Replies
- 698 Views
Last post by rcmatt007
