Keys cut by code are only $5.50 each.(includes shipping)Click here to order.
Keys for vintage Goldwings cut by code (and numerous other Honda's that use the same key blanks) 5 number, 3 number, and A00-D99. I can also cut keys for aftermarket ignitions that use H00-H99 codes. (Most aftermarket ignitions do not have the code on the lock, only on an original key.)
**NOTE** If lock or key has been altered, the code may not work.
If you have a working key and no code, I MAY still be able to help.
PM or email me at codecutkeys@gmail.com .
Available blanks, subject to change based on availability.
For 5 number codes (75 and 76 only. Brass or nickel plated.)
for 3 number and A00-D99 (77+)
Here are a few locations of the key codes.
A 75 or 76 ignition lock code 77890.
A 75 or 76 helmet lock code 29087.
A 77-82? ignition lock code 117.
A 78 or 79 Shelter cover code 508.
A GL1100 trunk lock code 616.
A 82-83 GL1100 saddlebag code A31.
A GL1100 cover code 314.
A GL650I luggage lock code 813
FS: Keys cut by Code
Moderators: alan hawke, Forum Moderators
- Keymaker
- Brass Member
- rtccp
- RIP: 1963-2017
Re: FS: Keys cut by Code
. Hello keymaster...I'm looking for keys for my early 80's gl1100 samsonite hard bag lock...the key code is 17087... Do you have any of these???.. Nick
1983 GL1100 Standard
Would an original key say DO9?
- roncar
D09 is a valid key code for 83 or newer bikes and many replacement locks (ie helmet.)
- calif wingnut
He was last active one year ago. Try sending him a message.
Last active:
Mon Apr 17, 2017 1:39 am
Last active:
I would like to order a pair of keys but the order link does not work.
- Sagebrush
Its a 10 year old thread.
- RIP: cookie
Haven’t heard from Roncar in years …
Yea it seems Roncar aka the Keymaster is not around any longer. I will lock this thread until such time as he shows back up.
- 4 Replies
- 300 Views
Last post by roncar
- 2 Replies
- 308 Views
Last post by calif wingnut
