westgl
#46
Post by westgl »
These Plugs are more than 2-years old, and have a bunch of miles?? on them.
I will be changing them soon, they are worn
Here is the Spark plugs from the Left side Cyl.'s
They are a very nice Tan, slightly darker tan, or on the very Slightly Richer side of perfect.
Not running Lean at all, or running to rich, they are a perfect example
These were taken in very bright, & direct sunlight
I should have put a white piece of paper behind the plugs,
as that back ground makes then look slightly lighter than they really are.
Engine is very happy
1983 GL1100I Beige was an Interstate, Now Naked, Refresh & needs repaint
1984 GL1200A Naked 4Cyl.Valkyrie, Single Valk. seat & Valk. Gas Tank
1986 GL1200 Naked Hotrod with some old school in the mix (Completely gone through) Better than new
1988 GL1500 76 k miles, Naked 6cyl. building into a HotRod trike. (Under Construction)
1999 GL1500 45K miles Runs excellent
2006 M109R 1800cc Naked Reverse Trike
previous bikes, (there are way too many to list)
westgl
#47
Post by westgl »
I have not been updating as zi do not see a lot of interest here as there is at two other gold wing site.
No question or communication.
So if you are interested in this It really Works Great, the Carb we are all using is the One that Works Right out of the box No re-jetting
You can see MANY, MANY more posts and there is a LOT interest at these other sites, there are several people that have already converted and ABSOLUTELY Love it.
Both threads have some of the same Info but also have different Info, and different people providing their own success stories.
Here is a couple of links
http://www.goldwingfacts.com/forums/2-g ... llent.html
and
http://www.classicgoldwings.com/forum/v ... f=9&t=6619
ianstaley
#48
Post by ianstaley »
I like the idea of a single carb, I got my 79 GL1000 from Holland a week back to the UK and have started to strip everything off; it is going to be a total rebuild from the ground up. The twist grip doesn't work any more, so the carb's are foobarb. I can't be bothered to boil the things for a week to get 2mm of movement or crud off what is basically a bunch of crap crabs too start with. So this looks the ideal solution. I have the chance of a FORD - Weber 28 / 32 TLDM Auto auto-choke Carburettor, it is new but never used, the auto chock can be removed, hopefully I can get it for maybe £40.00 but where the hell do you get the VW plenum for the conversion? is it a standard plenum on what VW. Old beetle or bus?
So any help on this will be great. I read some stuff on old wings forum too but you guy's are all about 1100's and not the 1000. Not that I see a lot off difference. Ian
westgl
#49
Post by westgl »
IanStaley
Look at post #47, it has two web site Links to go to in regards to this exact same info but MUCH MUCH MORE of it.
ianstaley wrote:I like the idea of a single carb, I got my 79 GL1000 from Holland a week back to the UK and have started to strip everything off; it is going to be a total rebuild from the ground up. The twist grip doesn't work any more, so the carb's are foobarb. I can't be bothered to boil the things for a week to get 2mm of movement or crud off what is basically a bunch of crap crabs too start with. So this looks the ideal solution. I have the chance of a FORD - Weber 28 / 32 TLDM Auto auto-choke Carburettor, it is new but never used, the auto chock can be removed, hopefully I can get it for maybe £40.00 but where the hell do you get the VW plenum for the conversion? is it a standard plenum on what VW. Old beetle or bus?
slammed86
Zinc Member
Zinc Member
My Album: slammed86
#50
Post by slammed86 »
Where did you get your silicone hoses for your intake?
'76 GL1000
triwing
Brass Member
Brass Member
#51
Post by triwing »
Has anyone else seen the bent intake runners done with 2, 1" PVC 45s cut & connected with silicone hose & clamp's? Seen it somewhere can't remember where, driving me nut's(well worse).
taunusrainer
#52
Post by taunusrainer »
Hello Westgl, You say weber 32 dft, but as I recall this carb was used on many engines with many different factory chokes and jettings.
Sometimes webers are numbered with a suffix, such as 32 DFT 70 or 32 DFT A3. Does Yours also have that?
kyote
Lead Member
Lead Member
#53
Post by kyote »
Hello All,
I'm working on an 84 1200, and have purchased a carb from Tom, as well as the EMPI plenum set. Problem- THEY DON'T BOLT UP!!!
The carb flange is smaller than the Plenum!!
I can modify the plenum fairly easily, but obviously prefer not to.
What do NGW Club?
Restore my hope!
kyote
Lead Member
Lead Member
#54
Post by kyote »
Pics
#55
Guess that Plenum is going have to be modified
kyote
Lead Member
Lead Member
#56
Post by kyote »
Answered over at CGW, sorry for noobishness :-P
#57
Tell us how it works out.
westgl
#58
Post by westgl »
I did Not modify the plenum at all.
I took a rotary file bit in my dremel tool and opened up the mounting holes in the carb there is a lot of meat around those mounting holes, took me about a 1/2 hour or less very easy just go slow and keep checking.
It is much easier than modding the plenum, I do not have any vacuum leaks at all.
westgl
#59
Post by westgl »
Sorry I did not provide a quicker reply.
I cannot update my e-mail address and I no longer have the e-mail address listed in my profile, so i have no idea when a reply comes in.
Alabaster
Lead Member
Lead Member
#60
Post by Alabaster »
I've been following this thread waiting for the final verdict. I've found the intake but I still haven't found any Weber 32/34 carbs. Can you get a part number for your carb. I'm dying to convert my GL1000 over to a single carb setup. Also, do you have any specifics about the tubing/hose you used. I'm not sure what the technical name for it is and I'd like to be able to get that locally. Thanks man, keep us updated!
