S.U carburetor
aussiewingman
S.U carburetor
just a quick question...
has anyone used S.U carburetors on their goldwing??
Re: S.U carburetor
omg, why would you? lol never ever want to see those again after owning an Austin Healy, MGB, and Nash metropolitan (beeb beeb)
aussiewingman
Re: S.U carburetor
basicly they're suppose to be great with superchargers....
any feed back on that....????
- Casper
Re: S.U carburetor
Check in with this chap, not sure if he is a NGW member or not?
On the serious side, I never had much luck with SUs, they sure did not like the cold weather we get in the winter. Like sunnbobb I had them on MGs, and a Nash Metropolitan(actually my first car). But perhaps others have had better luck.
Re: S.U carburetor
i always found that picture interesting. and i wondered where he put his feet
- salukispeed
Re: S.U carburetor
Is that some sort of 24 cylinder "X" configuration engine in that bike?
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
aussiewingman
Re: S.U carburetor
looks pretty radical....i reckon your nuts would cook after 5 minutes of riding....
- ianstaley
Re: S.U carburetor
Not only his nuts but he can't turn the front wheel either there is a cylinder head or something in the way. Although saying that an old biker friend I haven't seen for must be close on 44 years had a trike with a Jag V12 engine as power plant. He was on British TV with it if I remember right, I wonder if he it still alive..
aussiewingman
Re: S.U carburetor
(i'm interested in using a single S.U through a supercharger)
Sunnbobb i know what you mean when you mention old austins and mgb, and i agree those old twins were fiddley....
but there also are later SU carburetors with built in floats (not external floats) thats the ones to use....and only need to use one, then theres no messing around trying to get two carbs to flow even...
and just the cheapest way to go....
- ianstaley
aussiewingman
Re: S.U carburetor
beautifull car that bentley...
cars were very basic compared to todays cars....one valve for fuel and one valve for exhaust...now-days we have multi valve engines and i'm not an expert, but i think thats where most of engine modifications been done ( head porting, valves, induction and exhaust) and cranks and pistons havn't really changed as much...
the goldwing engine is a SOHC and would be about the best as far as i think when it comes to single a valve carburation and exhaust type of engine...
i've had a good look at using a down-draft duel throat webber or similar and they really have to be set up exact...
(remember i'm only interested in supercharging my engine on a tight budget)
now i just want to throw this option on the table as another alternative to the traditional duel-throat webber supercharger set-up
Re: S.U carburetor
Good to know Aussie!
- ianstaley
Re: S.U carburetor
The Early Bentleys didn't have a removable Cylinder head it was cast in with the block and then machined but there are other carb potabilities than just an SU. You could quite as easily use a Stromberg, which although a vacume operated choke was a lot smaller in height than the SU.
see first pic of twin Stromberg's probably off a Volvo 145s they would be typically designated CD125, CD175 etc. then next picture is the SU in cross section Diagram, you can see that the Stromberg is much smaller in height.
Hope this helps.
Hope this helps.
