Shortening Shocks
peteybug
#31
Post by peteybug »
Yes they work great on my bobber. I don't know how they would be on a two person bike. Smooth ride and no bottom out as of yet.
Dave_J
#32
Post by Dave_J »
78AZWing wrote:<<<Snip>>>I was thinking about heating the sidestand in the middle and curving it outward an inch or so to return the lean angle to a more acceptable angle. Any thoughts?
That should work ok but do it off the bike or not using the bikes weight untill its cooled, of corse.
As a side question(s), how is the cornering clearence with it dropped that much? What part drags and about what lean angle? I dont need a "Tame the Dragon" carver but it must corner without too much dragging of hard parts. I have low sided when a foot peg hit its limits and lifted/unloaded the rear tire enough off the ground. But that was a Honda 305, not a heavy Wing. DaveJ
Retired US ARMY Signal
Old Mopars TT 65 B-Cuda in the works, 78 Dodge LRT with 425 HP 360
80 GL-1100 Faux Interstate
03 Suzuki Burgman 650 Supersized Scooter - Darksided Potenza Car Tire on the rear
peteybug
#33
Post by peteybug »
So far I have not scraped at all but I'm not a real agressive driver. I lowered the forks about 1 1/2 in to help also. I took of center stand and have diff pipes. The bike is a blast to drive. The way its set up I sit flat footed when stoped. Im only 5ft 10in tall with a 30 in inseam. So not real tall.
gungadin
#34
Post by gungadin »
I had 11" shocks with the forks lowered a FAT 1". Also a 16" rear tire.
The bike was VERY low. I only ever scraped the nubs on the front pegs.
This does wake you up. I think the next thing to scrape would be headers.
I weigh 200+ and with my wife on 115 drippin' wet the shocks would only bottom out occasionally under servere load. My GL is more or less a bobber too so subtract a little weight.
I've gone back to OEM shocks but when I find a good pair to molest I'm going to do Peteybug's mod.
'75GL "LIL WING"
If you aren't making mistakes you aren't doing anything.
vintwing
Re: Shortening Shocks
#35
Post by vintwing »
I've been following this thread, and I like this idea. I have one small concern with this. You will be creating a different angle from the engine to the differential, will this ultimately be tough on the universal joint? Anyone have any thoughts about this? Norm
1975 GL1000 Antares red Nanaimo BC Canada
Jason J
#36
Post by Jason J »
I used your method to lower mine and it worked great. That universal has alot of room in it, if you ever have your engne out you will see how much.
http://www.nakedgoldwings.com/gallery/JasonJ
Bobalou
Zinc Member
Zinc Member
#37
Post by Bobalou »
Nice write up.
McLeod
#38
Post by McLeod »
peteybug, great post on lowing the rear shocks. Have you thought about lowering the front forks and giving us all your insight on that?
Boone, IA 50036
RIP: 1950-2011
#39
Post by Cookie »
Loosen four bolts and slide the tubes up? Tighten four bolts?
JohnBaxter
#40
Post by JohnBaxter »
With all of this Shortening of shocks, and reducing fork height, How does all of this affect the ease of putting the bike on the Center Stand ? I know that mine can be a little difficult when she wants to be. :8)
When the Power of Love
Overcomes the Love of Power,
Then and ONLY then
Will we find peace.
RIP: 1950-2011
#41
Post by Cookie »
It makes it harder.
#42
shorten the center stand action1 action1
datsunfreak
My Album: https://datsun510.com/index.php?/galler ... 0-project/
#43
Post by datsunfreak »
CYBORG wrote:shorten the center stand action1 action1
But unless you move where it bolts up the frame, it will no longer hit the muffler in the right spot. confused22
macmusick wrote:by the way if you get a message about a dead kitten just play along.
mogold
My Album: http://www.ngwclub.com/forum/viewtopic.php?f=30&t=37699
#44
Post by mogold »
I'm using this method...just a tip ...check and recheck the size of the threads. I used a bolt gauge template to check the size which looked like m12 1.25 .....it was actually sae 7/16 20 ......I know its weird and I don't understand why but I almost ruined my shock. Also ...because it is hardened steel...it stripped the die...I learned after talking to several different industrial tool companies..that the die's that are shaped like a socket are actually "thread chasers" designed to clean up existing threads and the round ones are made for chasing and cutting new threads....I bought the HS (high speed) round die and it held up well with no stripping.
CBGL Project thread http://www.ngwclub.com/forum/viewtopic.php?f=30&t=37699
1977 GL1000
CBGL Photo build documentation http://photobucket.com/cbgl
dennwhite
#45
Post by dennwhite »
I finally started this mod. I took a chance and bought a 12-1.25 die before I removed the shock. As close as I can tell my shock dia. is 11-1.25. I am having a tough time finding this die. Even the tap and die sets skip 11mm and if they have one it's 11-1.5. Silly Japanese. I tried a 7/16-20 tap and a 11-1.5 tap into the nut by hand and they would not go. I only found one online and they wanted about 15 bucks for it which is not bad. But they wanted another 15 for shipping.
