how to easily compress your shock springs
Re: how to easily compress your shock springs
Sorry but that just doesn't look too safe to me. Something like this http://www.ebay.com/itm/Laser-4764-Moto ... c2&vxp=mtr works much easier. And doesn't cost that much.
Rob, I have used click tighteners for lots of things and never had one fail on me. Holding a ton of glass against a rack, pulling two framing members together, etc.The trick is knowing how to loosen them smoothly. You can buy a set for around 15 bucks that will be more than enough to do a bike spring.
I trust you. It just looks spooky.
I have done the same with "big" zip ties
Spooky, yes, but it worked.
- delling3
I have a setup that works great for me. Go to the hardware store and pick up a couple of rigging turnbuckles, a couple of S-hooks, and a threaded rod or bolt about 2" long, with some matching nuts and washers. Install the turn buckles on either side of the lower clevis using the bolt/nuts/washers. Then unscrew the turnbuckle to an appropriate length, and use the S-hooks to connect the top of the turnbuckle to the springs. Tighten the turnbuckles a few turns at a time to compress the spring evenly on both sides.
Total cost of about $10. It has worked great for me during the restoration of two different sets of shocks.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
Update: An even easier way. Autozone has a program for renting tools. They sell you a spring compressor, let you use it, and return it with no hassle. They have a lot tools they will do this with.
- jimmyz3286
Or put the lower shock mount in a vice and have a 230lb friend hang on the spring while you put the retainer in place.
"The rain collected pools of images at my feet and they asked the direction to the ocean."
1982 GL1100 Silverback
2004 Roadstar For Sale
1981 CX500 café project for Anakin
Yes, finding a friend willing to lose his fingers was key.
Oreillys does this too. You buy the tool, use it, return for your money. I thought everyone knew that.sunnbobb wrote:Update: An even easier way. Autozone has a program for renting tools. They sell you a spring compressor, let you use it, and return it with no hassle. They have a lot tools they will do this with.
Well, uh, ya, I knew that.
- John Schmidt
Here's what I made to change the shock springs on my Valkyrie. A larger unit would be needed for something the size in the video, but it a bit safer than using those tie down straps....and faster. It's easy to build, I just used some aluminum scrap and cut the hole in the bottom just large enough for the top ring to pass through without the top spring cover going through. The tubes on the side are simple elec. conduit, the eye bolt has a small piece cut out to hook the top eye of the shock. Did that rather than heat and bend it open, possibly weakening it. I set the bottom in a vise and hook the top of the shock and start cranking. When I get it far enough up into the tool, I'm able to remove the retaining ring which works very similar to a valve keeper on a valve spring. Once the keeper is removed, just crank the eye bolt down to release the tension and the top will then lift off, followed by the spring. I started using a second nut on top just an extra safety measure in case the threads would strip on the eye bolt. Been using it for a few years now with nary a problem.
1984 GL1200 Standard, work in progress
1998 Valkyrie Tourer, my Honda Davidson
- Sugs
That is brilliant, very simple and easy to make. Thanks for posting!
_______________________
'79 Honda GL1000 Goldwing
- rudolphwolven
I WAS AT THE SAME SCHOOL AS FRED FLINTSTONE......
(we always had not enough pocket money)
........Yabadabadoooooooh.........
Proud winner of the NGWClub-USA contest Bike of the Year 2016---
--- GL1000 K1 1975
