As the table came down and the bar contacted the lower frame, the bar collapsed. That 3/4" steel bar bent like a wet noodle. There was no hesitation in the tables decent, it just kept coming down and the bar collapsed along with part of the frame. If I'd have continued depressing the 'release' peddle, the table would have continued it's decent. I backed off when I saw the bar collapsing.
So, rather than take both of them back to HF (highly disappointing and a major hassle), I'll be taking both of the lifts to a welder to have the frame reinforced and pick up a larger and better quality steel bar. I know a lot of you have this particular lift (#69904) and I'm encouraging you to, 1. Be aware that the safety bar is..., well, not 'safe' and, 2. Consider replacing the bar with one made of a higher grade of steel.
I've sent Harbor Freight corporate an email describing this failure and included the photos you see below. I (strongly) suggested that they pull this lift from their Web site and stores until the issue can be resolved.
