The NGW Project Bike. Body/frame/style
Locked
octane
#286
Post by octane »
halbritt wrote:... I'm assuming that your speedo is in km/h (got it up to 140?)
Yes...and you have to knock off some of that
as the front wheel is smaller
and you were in 3rd gear?
Nope. Second.
Strawb
#287
Post by Strawb »
hi octane ............... what happened to your AVON VENOM's?
'99 Honda CB400 Super Four Hyper VTEC
'81 Honda GL1100 Goldwing - WindJammer
http://www.nakedgoldwings.com/albums/album268
modernbeat
#288
Post by modernbeat »
halbritt wrote:One would assume that soldered connectors would be ideal, but it turns out that they aren't. At least as far as I know, the aerospace industry uses mechanical connectors (crimped lugs) as soldered connections tend to break under vibration...
That depends on the applicaton. The wiring harnesses used for the Shuttle and the Space Station are all terminated in couplers. On most cases, the pins in the couplers are first double crimped, then soldered, then additional layers of wire support similar to shrink wrap is placed along the wire, then it's potted into the connector, and then a jacket is placed on the entire harness.
The wire support layers are really key. For homebuilt stuff, two layers of tapered shrinkwrap over crimped and then soldered connections is almost overkill.
Ex nemo non feces.
27 years I worked on Helicopters as an Aviation Electronics Tech for the US Navy. To attach 2 wires together a crimp connection was considered a "temporary repair" to meet the flight schedule. At the end of the day you would cut out the crimp splice and do a solder repair. A good solder connection cleaned with a bit of Alcohol ( to remove flux residue) then a layer of heat shrink was considered a permanent repair.
halbritt
#290
Post by halbritt »
Apparently, there's no right answer, but there are staunch proponents on either side of the fence. I suppose as is often the case, it comes down the the skill of the person doing the connection. Here's an article on the topic:
http://www.virginiawind.com/tips/060801_01.asp
halbritt
#291
Post by halbritt »
Nope. Second.
I thought it might have been second, but I had difficulty believing it. It looks like you wound it out over 10k rpm?
octane
#292
Post by octane »
halbritt wrote:....
Yep. As I said ; the rev-counter lags behind,
so I just don't know that it's at 10500 rpm
till it's too darn late .-(
...besides I just do not have the attention-capacity
to check the rev-counter all the time.
I'm too busy desperately clinging to the handlebars,
hanging on to dear life
...ha ho
glforever_v2.0
#293
Post by glforever_v2.0 »
Even as distorted as the dash-cam is, you can still hear the sweet whining of the supercharger... I hereby suggest we change Lars' status from exhalted guru to Dhalai Llama!
Ride well...
'82 GL1100 Interstate, Stripped nude
'78 & '79 KZ650's (Wifeys)
zowie
Lead Member
Lead Member
Hey Lars, I do like the seat you finally put on there....
#294
Post by zowie »
Can you tell me what kind it is and where to get one?
Thanks very much,
Barry
I'm learning a lot from reading the group, great bunch of people. Thanks for all your helpful tips, makes me glad I bought a goldwing.
Everything in Moderation Including Moderation
octane
#295
Post by octane »
Hi Barry
it from a new Triumph Speed Triple.
Got it off Ebay.
It's a lot more confortable than it looks.
There's more about it and how it was modified here
(scroll down)
octane
#296
Post by octane »
glforever_v2.0 wrote:Even as distorted as the dash-cam is, you can still hear the sweet whining of the supercharger..
No. It's me whining in fear and terror
Thanks! I've started practicing levitation....not easy I tell you.
PS; do I have to wear a silly looking Tibetan hat now?
Octane, thank you, thank you, thank you for all you do to help out us mortals.
Being a graphic artist type I wanted to give a teeny bit back. I think this gif avatar shows off a little better without the white background. Just save it and use as type: GIF.
octane
#298
Post by octane »
THANKS a lot Steve !
Yeah...I like it!
I'll put it on right now.
Design revision, ala NGW P.B.
My pleasure, Octane.
But, like the NGW Project Bike this one had to be tweaked.
I had to round out the wheels and make them the same size.
Like you, I sometimes worry about things like ... is anal-retentive supposed to be hyphenated ... or is anal retentive just two words?
By-the-way, I loved this thread! Thanks again.
THESUPERSTONE
Lead Member
Lead Member
#300
Post by THESUPERSTONE »
octane wrote:(Z and Bart; we covered that in the other thread, right?!)
....YEEEEEEEEEEEEEEEEEEEEEEEEEEEES
Just ordered a set of these
same as these on Menkelwings
at only 120 US$ for a set....that really isn't too bad .-)
from in Germany
any comments ?
Envy ?...-)
Anything ?
HI OCTANE!
I COULDN'T FIND THE PIPES THAT YOU PUT ON YOUR BIKE...I'VE FOLLOW THE LINK TO LOUIS BUT I CAN'T FIND THEM...COULD YOU HELP ME?...WHAT IS THE BRAND, OR FOR FOR WHAT BIKE AND MODEL ARE OFFER, I DON'T KNOW...HELP!!!
WHAT AN AWESOME BIKE YOU HAVE BUILD MAN!
REGARDS!
JUST THE SUPERSTONE!
Locked
Return to “Octane's Corner”
