The NGW Project Bike.DYNA electronic ignition.How-to INSTALL
- GL1-242
Well sorry for all the questions and confusion. I got it wired up and ran to the stop. It wasn't right and a wasnt getting enough degree so I had to loosen the left side to fine tune it in.
She has never pulled this hard between 3,00 and 6,000. she is running sweet.
Thank's All,
Paul
Thank's All,
Paul
84 GL1200 STD
75 GL1000 #202
75 GL1000 (AKA, GL1-242)(AKA, Flipper)
76 LTD
76/77 CB750F
Bultaco's = 121, 152, 167, 188
75 GL1000 #202
76 LTD
76/77 CB750F
- uglywrench
Great tutorial!!!!!!!
I took my laptop into the garage with me and followed your instructions. Refering to the pictures as I went along. I'm sure that with out them I probably would of managed fine but it may taken me a bit. The Timing Tutorial was also great and a HUGE time saver
Thanx for your efforts.
Uglywrench
Uglywrench
Somebody had to try it....
1979 GL1000 Daily Rider
1983 GL1100 Current Project
- Silver Bullet
- My Album: http://ngwclub.com/gallery/SilverBullet
So, I'm memorizing this Dyna Install How-to- Tutorial while I wait for my Dyna Ignition GL '78 to arrive in the mail. The instructions and photos are excellent! I'm a Visual Learner.
But, I'm confused by the photo that shows connecting the Red Dyna Wire to the White/Green Turn Signal Wire. Am I "Tapping" into this Turn Siganal wire then reconnecting it to the signal flasher?
Also, what is the solid green wire in this photo?
Why is this White/Green Turn SIgnal wire the chosen power source? Would the accessory panel above it work as a power source for the new ignition?
I'm guessing that this will all be clear once I recieve my Dyna Directions in the Mail. I just couldn't wait! Thanks for taking the time.
[i][color=#FFFF80][color=#FFFF00]Silver Bullet[/color][/color][/i]
1978 GL 1000
1982 GL500 Silver Wing Interstate
1978 GL 1000
it is a switched 12VDC power source, the signals only work when the key is on. yes, the accessory panel will work, that's what I've used. any other steady 12VDC switched source that turns on/off with the ignition switch will work.Silver Bullet wrote:...Why is this White/Green Turn SIgnal wire the chosen power source? Would the accessory panel above it work as a power source for the new ignition?...
H2G2=42
H2G2=42
- roncar
I would assume the green/white wire was chosen for easy accessibility and power only in the "ON" position of the ignition switch. The accessory terminal has power in ON, ACC and PARK positions of the ignition switch.heraldhamster wrote:it is a switched 12VDC power source, the signals only work when the key is on. yes, the accessory panel will work, that's what I've used. any other steady 12VDC switched source that turns on/off with the ignition switch will work.Silver Bullet wrote:...Why is this White/Green Turn SIgnal wire the chosen power source? Would the accessory panel above it work as a power source for the new ignition?...
- Silver Bullet
Thanks for your feedback HeraldHamster and RonCar. I like the idea of getting Dyna Power from the Accessory Panel instead of "splicing" into the harness.
Some splices and crimp connections can weaken the wires, look messy and are exposed to moisture like the "Blue-CrimP" supllied with the Dyna Kit.
These "Blue-Crimps" infested my headlight bucket from the previous Vetter Fairing Installation. Many of these spliced wires were partially broken and corroded.
Soldering and Shrink-Wrap cleaned up the connections and left more "elbow room" in the bucket for the reflector 3-prong plug.
Anyway, I'm glad to know that the Accessory Panel works fine for the Dyna power source.
1978 GL 1000
1978 GL 1000
- tlday
- Zinc Member
Dyna III
Octane, I enjoyed your installation procedures until it got to the end where you show a newer Dyna system. I have the old Dyna III system on my bike and was hoping to determine if the installer had set it up correctly. I have a problem with the performance of my 1979 GL1000. It starts and runs, but doesn't seem to have the power it should have under load. I have done a timing belt replacement, compression check, valve adjustment, carb clean Randakk style, and added Seafoam to the fuel to help lubricate and clean the upper engine and carbs. Something just isn't getting through my pea brain here. I surmized that if I had erred in installing the belts, even by one tooth, the valve clearance would have been off by more than a thousandth or two, which it wasn't. I just brought them into spec. because I had the covers off already.
Since the Dyna III has two pickups which can be individually adjusted, I was wondering if one might be a little off, but I really don't know how to check that. I would also like to check the advance mechanism to see if it is operating freely, but I'm afraid to take the Dyna III out of the housing without knowing exactly how it is set up. Maybe I should just take it to a shop and have the timing adjusted by the experts, but from the looks of the screws on this mechanism, somebody has already tinkered with it too much already. However, I am encouraged by the compression which checks 170-180 and the accuracy with which the valves had been adjusted, and the fact that the bike only has 29,000 miles on it. That all leads me to believe the problem is either in the timing advance or the timing itself.
Any hints?
Any hints?
Govnrs Dream
"The more I know, the more I know I don't know" I'm always eager to learn more.
"T. Day"
Oxford, OH 45056
"T. Day"
Oxford, OH 45056
- octane
Re: Dyna III
The DYNA in my above pictorial does have individual adjustmenttlday wrote:Octane, I enjoyed your installation procedures until it got to the end where you show a newer Dyna system. I have the old Dyna III system on my bike ................
.....Since the Dyna III has two pickups which can be individually adjusted, I was wondering if one might be a little off, but I really don't know how to check that...
for the two pick-ups.
For adjusting please click: DYNA ignition adjustment
...and I'm guessing yours adjust the same way.
I'm a bit confused as to what Dyna you have.
How does yours look different from the one in the pictorial ?
- tlday
- Zinc Member
Dyna III
I have a Dyna III. I don't know how old it is. My brother buoght this bike new in 1979. I assume that he went to the electronic ignition to eliminate the maintenance. The difference I saw was that the holes to lock down the pickus were actually open-ended slots.
Somebody has evidently had a lot of trouble adjusting these because the screw heads are all gnawed up. I'm going to replace them today. But I still don't know how to make the adjustments to get this timing just right. I do have a timing light and a viewing plug. I guess I'm all set!
Govnrs Dream
"T. Day"
Oxford, OH 45056
"T. Day"
Oxford, OH 45056
- octane
Re: Dyna III
I'm sorry:tlday wrote:I... But I still don't know how to make the adjustments to get this timing just right. I do have a timing light and a viewing plug. I guess I'm all set!
I'd like to help but
I'm confused.....please; exactly what part of the adjustment procedure
is it you have problems with ?
The Dyna in the linked pictorial does also have open-ended slots.tlday wrote:...The difference I saw was that the holes to lock down the pickus were actually open-ended slots....
You sure it''s a Dyna III?
..does it have a small black box somewhere?
Those were (as far as I know. I could very well be wrong) not for the GL's.
Here's a link to installation / trouble-shooting guides:
[EDIT]
Click: DYNATECH DOWNLOADS
----> click the "LOOK UP" field
a 'roll-down-curtain' appears --> click DYNA III
.....and you'll find what you're looking for.
Hope this helps!
- tlday
- Zinc Member
- octane
Here are tlday's photos and text.
Hopefully someone can help, cause I have no idea about
those thingies.
Please; did you check the link to the Dyna-tech downloads above???
There you'll find:
DYNA III Electronic Ignition Troubleshooting Guide
and
DYNA III Electronic Ignition Installation Instructions
which have all the answers as far as I can tell.
"....What I have is a bundle of wires coming out of the Dyna III module, going to the points housing. There is a red wire, white wire, and a black wire going to the pickups. There is a yellow wire and a blue wire also coming from the Dyna III module and they are going to (a yellow wire with a blue stripe) and (a blue wire with a yellow stripe) respectively. I am assuming that the striped wires are coming from the coils...."
those thingies.
There you'll find:
and
The 76 I just sold had the same system. It is just an older Dyna. Use the same process to do the Timing. I do it static by hooking up a test meter or light where the wires from the Dyna go into the Bikes harness under the LH Side cover.
WF is correct. The Dyna III was the early version. Then with new technology they were able to put everything on the plate and eliminate the box. Timing procedure is identical.
- 23 Replies
- 5267 Views
Last post by robbie202
- 5 Replies
- 2493 Views
Last post by robin1731
- 13 Replies
- 4000 Views
Last post by Sidecar Bob
- 9 Replies
- 3485 Views
Last post by pidjones
- 3 Replies
- 1612 Views
