BRADSHAW BIKES POLISHING & RESTORATION CATALOG 2016
Miscellaneous GoldWing Related Parts, and GoldWing for sale.
Moderators: alan hawke, Forum Moderators
BRADSHAW BIKES POLISHING AND BIKE RESTORATION SERVICES
POLISHING SERVICE
CARB TOPS (set) $50
INTAKES (set) $40
TIMING BELT COVERS (pair) (any year) $57
GL1000 Valve covers (pair) $57
GL1100 Valve covers (pair) (Includes new painted emblems) $57
GL1200 Valve covers (pair) (Includes new painted emblems) $57
FRONT FORK LOWERS (pair) (75-82) $90
FRONT TRAC FORK LOWER (pair) (83-87) $95
OIL FILTER COVER $20
1200 FORK BRACE $25
POINTS COVER $15
FRONT WHEEL HUB $35
REAR WHEEL HUB $65
TRIPLE TREE $175
CLUTCH COVER $38
FINAL DRIVE $285
SHOCK MOUNT $15
POLISHED PARTS (WE SUPPLY THE PART)
GL1000/1100 Valve cover set $95 (except 83)
83 GL1100 Valve cover set $110 (No "made in Japan" on cover)
GL1000/1100 Timing Belt cover set $90
GL1000/1100 Intake Manifold set $85
Tach/fuel pump fitting $35
Points cover $25
Fork lowers $105
Thermostat Housing and pipe fittings $95
Water pump cover $25
Right side inspection plate $35
Oil sump cover $25
Oil filter cover $45
Clutch Cover $40
Final Drive $225
GL1000 right rear lower shock mount $25
Polished Fork Brace $165
"VYPER" handles set $85
TAROZZI FORK BRACE POLISHED $189
OTHER SERVICES
4 lbs of fasteners run through our tumbler $25 shipped
HIGH TEMP POWDER COAT HEADERS (1000 degree rated) Choice of black or silver $100
HYDRAULIC CLUTCH CONVERSION Kit $195
To order, pm or email Sunnbobb@gmail.com your part list. We will send you a paypal invoice with the amount due and the shipping address. In most cases we strive for less than 14 day turn around.
CATALOG
CARB TOPS (set) $45
INTAKES (set) $38
TIMING BELT COVERS (pair) (any year) $59
GL1000 Valve covers (pair) $50
GL1100 Valve covers (pair) (Includes new painted emblems) $55
GL1200 Valve covers (pair) (Includes new painted emblems) $55
FRONT FORK LOWERS (pair) (75-83) $75
POINTS COVER $15
FRONT WHEEL HUB $35
REAR WHEEL HUB $65
TRIPLE TREE $145
CLUTCH COVER $38
Points cover $15
Fork lowers $105
Oil sump cover $25
Oil filter cover $35
Clutch Cover $40
Final Drive $225 (yours $185)
HIGH TEMP POWDER COAT HEADERS Choice of black or silver $105
Turned Brake Disks $110 (set of 3)
Drilled $35 per rotor
"VYPER" HANDLES $85 set
Tarozzi polished fork brace (GL1000 - GL1100) $189
HYDRAULIC CLUTCH CONVERSION KIT $195
This is a kit for converting your cable driven clutch to a later style hydraulic clutch. Included in this kit:
1 refinished Clutch Cover w/ new Honda OEM seal painted either aluminum or black - polished add $20
1 Rebuilt Hydraulic Slave Cylinder new seals, spring etc.
1 New 48" Stainless Steel AN3 line
1 New Male to Male AN3/10mm connector
1 New Clutch Cover Gasket
1 New Custom made Stainless Steel push rod
This kit is ready to hookup to a Hydraulic Master Cylinder. Simply remove the old clutch and install this one and install the master of your choosing. You will also need a 10mm x 3AN banjo adapter with the angle of your choice, and a 10mm banjo bolt if you are using the gl1200 master cylinder. T All parts have been professionally reconditioned and rebuilt to like new specification.
GOLDWING ART PRINTS
8x10 $15
8x10 matted $20
Price includes delivery
gregforesi
Re: BRADSHAW BIKES POLISHING & RESTORATION CATALOG WINTER 20
Post by gregforesi »
I don't know about the rest of the parts, but I do know that's a good deal on a final drive.
I had an "amateur polishing moment" yesterday involving a flying carb top. As a result I'm thinking of installing a padded cell for polishing. I just gotta figure out how to hold the parts when I've got the belted white jacket on.
Inside my padded room no one will hear me crying.
2006 GL1800 (Brutus Maximus)
AODRN
Post by AODRN »
I'm sold. Where do I send my stuff?
1979 GL1000 Gordians Knot (In progress)
2010 Ninja 250 track bike
Pony Ruiz
Post by Pony Ruiz »
Wow
nice stuff.
1978GL1000 naked - 39k longest build ever.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
Now there's a catalog I could browse through for the entire winter.
Blingage!
I thought it was about time I pulled everything into one post. :)
I forgot to mention ordering info. Added to the first post.
Gowing
Post by Gowing »
Those parts look fantastic,
How do, for instance, the fork legs and valve covers wear?
That is polished aluminum right?
It looks like chrome. Do they slowly paternal and corrode?
Thanks dave
Dave
1975 GL 1000
1976 GL 1000
1980 XS650
2003 ST 1300
1971 CT90
1972 F7 KAW 175
1984 elite 80
2004 Chinese 150cc scooter.
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2 (Dot)
Chihuahua #3 (Blaze)
I'm hoping you meant patina. Paternal is something my father did ... ;)
Bradshaw did my parts and all I've had to do is rub them down every other month with aluminum polish. Still look like sterling silver.
Nothing like a testimonial.. thanks Roady!
And another happy customer! Thanks Dritzman!
After:
Before:
Shameless bump
turboter
Post by turboter »
Sunnbobb,
Looks like great work!
Just wondering if you have ever thought of expanding,like polishing early honda cb 750 engine parts?
TurboTerry
1975 Blue green Gold Wing Original owner
1975 candy anteres red Gold Wing
1974 Freedom green metallic CB 750 K-4
1986 Mustang G.T. convertible
1986 Buick Regal T-Type
1987 Buick Turbo Regal
turbo, I frequently do parts for other bikes, but have not, as yet, cataloged them.
northwood
Post by northwood »
After polishing, do you clearcoat the parts? To keep them looking good?
2015 Honda Grom (Soon)
2006 Honda VFR800 "Snowflake"
2007 Honda "Chicken Bacon Ranch" (CBR1000RR)
Previous Bikes:
1975 Honda "ol' Bird Dog" GL 1000 (Gone but not forgotten)
1982 Kawasaki AR80 (The one I will regret selling)
1982 Honda CM450E Not so Project "Connie"
1987 Yamaha Virago XV535
2005 Triumph Daytona 650
NW, we do not. There is controversy regarding the practice. I fear that clear coat would trap moisture underneath and make it hard to keep them looking nice. I have found just a wipe of metal polish once in a while will keep them looking bright. I have wanted to try a crystal clear power coat though...
Return to “For Sale”
