Ram air?
- trevor42
Ram air?
Greg Foresi's latest endeavor http://ngwclub.com/forum/viewtopic.php?f=47&t=43563 got me to thinking (which is usually where the trouble starts). Has anybody ever experimented with ram air on a 'Wing?
I know some manufacturers-Kawasaki comes to mind-have successfully implemented ram air into their bikes.
What problems could be encountered by forcing more air into the carbs as road speed increases?
"No battle plan survives contact with the enemy." - Prussian field marshall Helmuth Karl Bernhard Graf von Moltke
1979 GL1000 - rebuild in (slow) progress
Re: Ram air?
trevor42 wrote:Greg Foresi's latest endeavor http://ngwclub.com/forum/viewtopic.php?f=47&t=43563 got me to thinking (which is usually where the trouble starts). Has anybody ever experimented with ram air on a 'Wing?
It's possible. But tuning ram air with CV Carbs is the tough part. It has been mentioned many times. CV carbs do not like moving away from the stock air box. It takes time and a lot of patience to get the jetting right if you do.
Cyborg has a sort of ram air tube in his bike. But it is one small tube feeding the stock air box (I believe). So it isn't that much different. He seems very happy with that.
Re: Ram air?
my system uses a tube about the same size as the intake nozzle on the air cleaner. the air box is sealed to hold pressure, and draws its air from the front of the fairing. at speed, rather then the air being drawn in, it is forced in. at 75mph the internal pressure of the air box is only about 2lbs. however the air is cooler then the air it would normally get from off the coils in the stock configuration. also a slight amount of pressure causes a little more air to enter the cyl. then is normally drawn in by cyl vacuum. this does cause a slightly lean mixture at speed, which can be cured by raising the needle. performance increases are really not that noticeable. the main one being that the engine likes the cooler air better
- fish
Re: Ram air?
ram air is a marketing ploy & a gimmick
Any ram or scoop big enough to make an appreciable difference is going to cause aerodynamic drag that equals the amount of HP increase.
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- Hal
Re: Ram air?
I'd say it's more worth doing from the point of view of letting the engine breath cold air rather than hot.
I have two larger tubes feeding the airbox, both running to holes in the front of the faux tank sides. The air around the coils, above the engine, must get quite hot, and the mouth of the spout IS very close to the coils.
Twin intake airbox...
Insect eye intake hole....it has a matching duct behind it. Negligible ram effect though.
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
Hal's Nalbum
1977 GL1000 in bits
1978 SR 500 Yam
Hal's Nalbum
- fish
Re: Ram air?
You have a good point Hal.
Here in Arizona my NGW does not mind the heat & runs fine no matter how hot it is.
My air cooled Volkswagon gets pre-ignition when it is 50c.
my cylinder head temp gauge and oil temp gauge are in range so I know it is not overhearing.
soooo.. I see the benefits of lower intake air temps.
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- egelasi
Re: Ram air?
First thing I thought of when I saw that dual intake
Current Bike: 07 Yamaha Road Star 1700 Midnight Silverado
Previous bikes:
76 GL1000LTD
99 Valkyrie Interstate
99 Aero 1100
85 GL1200 LTD with California Sidecar and trailer
88 Ducati 750 F1s
88 Ducati Paso 750
86 Kawasaki Concours
79 Honda CBX
85 Kawasaki Voyager 1300
77 Moto Guzzi Convert with Jupiter Sidecar
72 Moto Guzzi Eldorado
A horrible Suzuki Madura 700
69 Honda CB750
Yamaha XS650 Special
Honda CB350
Honda Z50
I might remember a few more.
Previous bikes:
76 GL1000LTD
99 Aero 1100
88 Ducati 750 F1s
88 Ducati Paso 750
79 Honda CBX
69 Honda CB750
Honda CB350
Honda Z50
- SloMo228
Re: Ram air?
egelasi wrote:First thing I thought of when I saw that dual intake
Re: Ram air?
I think the small amount of overpressure that could be gained from running at speed is only worth the tuning effort to a racer, not so much worth the effort to a streetbike. The cold air benefits are worth the effort though in my opinion. Colder, denser air is worth it to me to a point.
I've these BMW fairing vents I'm going to mate to my Vetter sooner or later:
Re: Ram air?
I like that dual inlet airfilter box up there Hal. Looks like you've done a nice job on it.
Re: Ram air?
like i stated, i think the cold air advantage is a good one
- trevor42
Re: Ram air?
Hal,
That intake and airbox are very nicely done!
The cooler intake air temps are something I hadn't considered. Colder air, being denser, could certainly provide some benefits.
