CROSS OVER PARTS LIST
Re: CROSS OVER PARTS LIST
A poor fit on my 1100 as well.
Removed from the list.
- Marc
I think he meant Napa Gold Part Number 3011. 3001 is much too big, 3011 has a 1.4" diameter, just a little bigger than our stock 1.25" OEM filter but will fit if you use a little bigger screw in the filter bracket and bend the tab that the screw goes in very slightly.I don't know if anyone posted this part number but I just got a Napa auto parts Gold fuel filter for my ~3/16 or 4/16 fuel hose the filter p/n that's the right fit is 3001. Jdept
Couldn't find a cross reference for an air filter??? Anyone know of one?
Shalom, Marc
1975 GL1000 "Dresser"
1976 GL1000 Project Bike
1979 GL1000 Naked
2007 Triumph Bonneville
1970 Norton Commando
1979 GL1000 Naked
BikeBandit has aftermarket filters. They fit right nice.
- Marc
The price is right too: $11.01 with free shipping. I'm just not to comfortable with the EMGO brand. Might give them a try, if the fit is good there is not much to go wrong with an air filter.
Shalom, Marc
1979 GL1000 Naked
1979 GL1000 Naked
- britman
Ive been looking for an 83 speedo cable couldn't find one for an 83 . But a GL1500 speedo will fit has the same end as the 83
1983 gl1100 fully dressed the best colour black -- 1982 gl1100 going naked and black too 1983 Yamaha virago 700 also in black
- trevor42
Spark plug boots:
NAPA part #: NGW8072
"No battle plan survives contact with the enemy." - Prussian field marshall Helmuth Karl Bernhard Graf von Moltke
1979 GL1000 - rebuild in (slow) progress
Thanks, I've added it to the list.
(Part # seems appropriate, NGW=NakedGoldWing
- Scottinaz
according to Napa, there has been a supercession on the radiator cap part number. New number is 703-1697
'76 GL1000
List has been updated.
- taylorsel
Radiator hose
I went into auto zone and gave the part number in the first post- AutoZone - #B70834 ($9.95) does both top & bottom and got the deer in the headlight look
They let me look and I found a hose that fit better than the last few i got.
B71382 cost about $10 and I got both the top and bottom out of one hose
STEVE LOGAN, 1979 GOLDWING, 1978 GOLDWING, 1976 GOLDWING
- Marc
Thanks, I will try that.
Shalom, Marc
1979 GL1000 Naked
1979 GL1000 Naked
- Rusty Probie
Is there a part number for a 83 gl1100 temperature sending unit. Maybe Napa or Auto zone?
- d9canada
- Brass Member
Re: Motor swap
I understand this is an old thread but I have a question that hopefully someone can answer. Regarding the above quoted post - am I right in assuming that the key information is that the 1100 final has 'faster' overall gearing (numerically lower reduction) than the 1000? And will the 1100 final bolt up to a 75 GL1000?Sidecar Bob wrote:If you run an 1100 transmission and a 1000 final drive the gearing will be way too low.stkelly2 wrote:Any body know if I can replace my 1000 with an 1100? I know the motor will bolt right in but what other issues Might I run into?
I have the opposite - a 1000 engine/transmission and an 1100 final drive and the overall gearing is more than a gear higher - the mileage is a lot better and I don't find myself looking for 6th gear nearly as often.
Also regarding parts interchange, does anyone know if the 75 GL1000 grab bar is the same as any other Honda model/year?
And one more query, see my recently purchased GL in my profile pic - the seat bolts up to the original mounts so I assume the seat pan is OEM. The pan is in great shape, no rust or obvious alterations. Does anyone know if the seat foam/cover is a Honda spec or does it look like a Saddlemen kit or similar? I'm sure it's more comfy than the old breadloaf but I'm just curious.
Barnzie
82 CBX Prolink
75 Goldwing GL1000
81 Silverwing GL500 & 82 Interstate
83 CX650E (Euro version)
Honda 4s 350F-900C
Motorvation Formula II sidecar on CB900C
Sandcast CB750 1003245
63 Honda C105T 55cc Trail
83 Honda 750 Shadow
73 Norton 850 Commando
79 Yamaha XS1100SF
02 Sportster 883
82 CBX Prolink
75 Goldwing GL1000
Honda 4s 350F-900C
83 Honda 750 Shadow
79 Yamaha XS1100SF
02 Sportster 883
- taylorsel
On your seat It is an aftermarket seat not OEM. It might be a saddleman. dont know. Some of those seats used original seat pans. I had one. I just modified the foam to fit a original type seat cover. Original seats are a little hard to come by. Look to spend $150 to $200. And you'r right, origanals are not as comfy.
