single carb
phillip0123
Re: single carb
Post by phillip0123 »
No I don,t have any pic,s but HOTT has a thread on this forum titled SHADE TREE carb solution or something like that. Looks just like the one shown in his writeup.
Phil
79 GL1000
93 GSX1100
09 nomad 1700
murrayf
Re: single carb
Post by murrayf »
what jets did you settle on? my idle is rich highway mileage is good 45-47
Our Current Bikes at home
CX650 Deluxe turned out awesome a treat to ride
1983 GL650 naked
1983 GL650 full dress
2 1978 CX500 WHAT????? i like them
1981 gl500 Rachels build
1978 cx500 BIG 650 motor dual 38mm mikunis
1980 cb750 DOHC dual mikunis vance and hines exhaust
1971 cb750 SOHC dual mikunis
1966 cb350 dual mikunis baby 28s
1975 GL1000 owned since new
1977 Gl1000 dual 38 Mikuni carbs New Daily Rider
1976 GL1000 ltd
1983 GL1100 full Tupperware Dual 38 mikunis
1978 CX650 Deluxe my toy Dual mikuni 36mm
katmol
Re: single carb
Post by katmol »
Hey phillip0123,
What jetting did you wind up with in the 32/36?
Thanks.
Old Naked Wings and SOHC 750's
vagrant50
Re: single carb
Post by vagrant50 »
I live in Charleston SC. I do not have a heated manifold with a weber 32/36. I only had a problem one time when it was 28 degress out. Bike didn't want to start or stay running. However I did make it home.
Brent
I can build anything you can afford!
http://community.webshots.com/user/vagrant50
phillip0123
Re: single carb
Thought this thing was sorted out---wroong!
Can get decent idle in the shop but go for a ride may not idle at stop sign. Sometime will but mostly not.
Will fiddle with float level today and see what happens.
Beginning to suspect a decent idle is next to impossibleness.
Phil
79 GL1000
93 GSX1100
09 nomad 1700
Re: single carb
Post by HOTT »
Phillip, Drop me a PM. Let's get it fixed.
vagrant50
Re: single carb
Post by vagrant50 »
I have a weber 32/36 on mine. It has the factory jet settings from Carbs unlimited. It Idles great at 1000 to 1100. There are no dead spots per say. Maybe a weak spot or to but I quickly adjusted shifting techniques so there are no worries. Had her up to a hundred or so. That is about it with that carb. I built the manifold myself and was told the runners need to be as close to same length as possible. No perfect as the carb has to set in the frame with the filter on it. I was also told to keep the plenum as close to the same size as the bottom of the carb. My plenum is about the size of all four inlets. I have no heating system on it at all. I have had no issues with freezing except for when it was below freezing. Ridin in 35 degree weather alot with no issues. There are pictures of the setup in my posts under unique carburation.
Ron
Re: single carb
Post by Ron »
I would like to talk to Patrick McCabe about his solex set up , how did you fabricate the throttle , with double cable twist grip to single cable ? Would a solex 30 pics work inside of the 35
"X"
1976 GL1000
Re: single carb
Ron wrote:I would like to talk to Patrick McCabe about his solex set up , how did you fabricate the throttle , with double cable twist grip to single cable ? Would a solex 30 pics work inside of the 35
Try sending him an email. He has not logged in here for over 2 years so odds are high that he will not see your note.
Ron
Re: single carb
Post by Ron »
tried going to his profile and e-mailing but will not let me .I'm not the greatest with computers .
"X"
1976 GL1000
Re: single carb
Ron wrote:tried going to his profile and e-mailing but will not let me .I'm not the greatest with computers .
Try sending him a PM instead. That should send a notification to his email.
