Another GL1000 Manifold for Weber 32/36
- CBX n GL man
Re: Another GL1000 Manifold for Weber 32/36
Excellent fab work, hope it all works out. Later.
'81 CBX nekid
'80 GL1100 w/windjammer
'80 CX 500D 1/4 nekid
'84 GL1200A 1/2 nekid -- gone
- Zinc Member
Hi,
@gregforesi: Yes, it's excactly this type of center piece.
igotbadbrains, thanks for the advice. I'll check for air leaks and let you know!
Thanks to everybody for your appreciation and advices!
Weather is still bad
Karl
Karl
CBX 1000 CB1 red
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
- Zinc Member
Ok,
since it's warm now I spent the day yesterday with tuning. Bike is now running pretty good. Surging in idle is still there, but not as bad as before. I observed, that after reving up and let the Gas "slip" back the bike is reving up and down for 2 or 3 seconds and is then stabilizing it's idle. No false air - I checked the system with some brake cleaner and no reving up. I assume, that fuel is falling out in the plenum because of to much acceleration enrichment. What do you think, could that be? There is no way to adjust the acceleration pump mechanism. Any ideas?
Thanks in advance.
Karl
P.S. I started another thread with another idea.......
Thanks in advance.
Karl
CBX 1000 CB1 red
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
- gregforesi
Does that carb have a bypass jet for the accelerator pump? Many Webers do. A larger bypass jet will flow more fuel back into the float chamber.
2006 GL1800 (Brutus Maximus)
- Zinc Member
Thanks Greg,
I'll check tomorrow.
Karl
Karl
CBX 1000 CB1 red
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
- Zinc Member
Ok,
short update. The bike is licensed and running! Very good idle and nice acceleration. But there is still a flat spot around 3500 rpm. I can get around it if I "pump" some fuel with the acceleration pump into the carb but that can't be the solution. It is from the spark plugs look still a little rich but obviously not all over the map.
Karl
Karl
CBX 1000 CB1 red
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
- plippo
thanks for the update - make a video of her running?Don_Karlos wrote:Ok,
Karl
Fil, Italian but now in the US..
Work in progress: GL1000'77 , a 76 LTD and another 75 being restored, a 76 750 four frame up ready to re assemble.
Riding a CB750 '72 and a blue GL1000 75 ;-)
left home in Europe: Blue 76 for sale, Red 77 (now sold), Black 78.
