Flow rate injectors GL1200 SEi
socrace
Re: Flow rate injectors GL1200 SEi
There's a good chance running 3 bar through the reg for a few min will flush out whatever is causing that low pressure leak out the return hose.
- kb0ou
Did taunusrainer ever get that beast running???
Gotta know........
Gotta know........
1979 Goldwing gave it away... :(
Bump
- taunusrainer
no, it doesn't run, but I think I am close to locating the problem...
1976 GL1000 test mule
1969 Ford 17m 2.3V6
1990 Mustang 5.0 7up conv.
1969 Ford 17m 2.3V6
bumpy new year
