Kei Hin Carbs
biggyfries
Re: Kei Hin Carbs
I was wondering when someone would mention Randakk's video--I bought the kit and the video and did my own rebuild and when it went on and the fuel went in and it fired up like a new bike--and it ran PERFECTLY for about a day. I was puzzled, but I found out what the problem was--I hadn't cleaned the plenum orfices adquately, and I had no tiny wire screens at the main needle/seat. There was a bit of junk in the fuel tubes or orfices. I finally got the entire thing clean as it says in the vid, and it runs like a champ--PERFECT again. Its like anything else in life--you do your best and still things can go wrong, but eventually you win in the end and I am now something of an expert on these GL1000 carbs. When they are right they are PERFECT! The video reveals everything. Don't skip any steps!
I can remove carbs in unbelievably short time now that I'm all practised up. I should time myself some day. It will be just a few minutes. I invented a little wire hook that speeds the installation of throttle cables, and a special claw foot wrench to tighten the throttle adjuster nuts--it is easy when you're all 'practised up' as I am. When everything is spotlessly clean and all the threads are new or perfect--it just zips apart or back together. Nice.
'79 GL1000
'16 KLR650 Blackie
'02 KLR650 Eyesore
'16 KLR650 Blackie
'02 KLR650 Eyesore
- Ruffrider
- My Album: http://www.ngwclub.com/gallery/v/wingmans/Ruffrider
Re: Kei Hin Carbs
could you post pics of your special tools. I can almost see them in my minds eye but a photo speaks a thousand words.
Current Bikes I own:
1975 GL1000 Naked Wing, Old Faithful (alias the Ditch Dog)
(88,000 miles and broke down now)
1975 GL1000 Dresser ( project bike, still waiting for me to finish) 20,727k on speedo.
1979 XS1100sf (18,600 miles)
1984 CT110 2300 miles
1978 CT (Trail) 90 1,650 miles on speedo
Past Bikes:
1979 750 Kawasaki LTD
1976 Honda CB360
1975 Honda 400 four
1966 Honda 160 Dream (should've keep 'em all )
My album
Past Bikes:
1976 Honda CB360
1975 Honda 400 four
My album
Re: Kei Hin Carbs
I have a nice long finish nail with a short 90 degree bend at the end, I clamp that in a pair of small vice grips and that is what I use to assist routing the cables onto the bellcrank.
- Tbell
Re: Kei Hin Carbs
I have a set of forceps that I use for hooking the cables.
Tom
Connoisseur of fine wings
76 Yellow gl1000 Total rebuild
93 Black gl1500
2004 NRX1800 Black Cherry Rune
Having enemies is not necessarily a bad thing! It means that at some point in your life you have stood up for something.
93 Black gl1500
- hoganJr
Re: Kei Hin Carbs
that is a great tip!Tbell wrote:I have a set of forceps that I use for hooking the cables.
thanks!
hoganJr
1991 GL1500
bikerdad5
Re: Kei Hin Carbs
once they work they work but Mikuni's are alot easier and more reliable, Have a set from Yamaha Venture I am going to get to fit my 77.
Why should I press one for English?
1977 GL1000 basket case/resurrection project.
- terry_208
Re: Kei Hin Carbs
I use a piece of coat hanger with a short 90 on one end the other end has a longer 90 for leverage.Whiskerfish wrote:I have a nice long finish nail with a short 90 degree bend at the end, I clamp that in a pair of small vice grips and that is what I use to assist routing the cables onto the bellcrank.
Terry
1976 GL1000
1976 GL1000
- Dog Boy
Re: Kei Hin Carbs
I realize this is an old post but am presently preparing to reassemble using a Randakk kit. As the original owner, I know these carbs have not been molested until now. The carbs were literally glued shut with varnish from evaporated fuel from the idiot PO not pickling them before "I" stashed the bike in 87. All parts were "crock pot" boiled, followed by an ultrasonic treatment, followed by compressed air. I've watched Randakk's DVD at least 3 times just to make me more familiar with the process. I'm finally feeling confident enough to reassemble these bad boys, so I give them one last "look over". I didn't feel warm and fuzzy with the looks of the "brass". I bought some carb cleaner and not not only shot the brass but soaked same in the cleaner. I couldn't believe how much additional particulate fell out of and off off the internals. The next couple of days will tell the tale. If after all is said and done, I end up having to remove them from the bike to address an issue, I feel confident I will be able to diagnose and correct same. Here's one pic of one bowl when I first disassembled them. They were all this bad or worse.
AL
AL
They call me "Dog Boy"
Can't blame the "PO"
Original owner 76 LTD
Team 993
Team 993
Re: Kei Hin Carbs
PO's can be such a pain!Dog Boy wrote:I realize this is an old post but am presently preparing to reassemble using a Randakk kit. As the original owner, I know these carbs have not been molested until now. The carbs were literally glued shut with varnish from evaporated fuel from the idiot PO not pickling them before "I" stashed the bike in 87. All parts were "crock pot" boiled, followed by an ultrasonic treatment, followed by compressed air. I've watched Randakk's DVD at least 3 times just to make me more familiar with the process. I'm finally feeling confident enough to reassemble these bad boys, so I give them one last "look over". I didn't feel warm and fuzzy with the looks of the "brass". I bought some carb cleaner and not not only shot the brass but soaked same in the cleaner. I couldn't believe how much additional particulate fell out of and off off the internals. The next couple of days will tell the tale. If after all is said and done, I end up having to remove them from the bike to address an issue, I feel confident I will be able to diagnose and correct same. Here's one pic of one bowl when I first disassembled them. They were all this bad or worse.
AL
- Dog Boy
Re: Kei Hin Carbs
Hahaha! Yep, they can be real jerks!
AL
AL
Team 993
Team 993
- sgwilly
Re: Kei Hin Carbs
I'm glad this thread got revived. I missed it the first time around and that first post is a hoot to read.
My direct experience with an 83; Bike has never been stored longer than 3 months since new. Carbs have never been off - annual synch and Seafoam has been the only maintenance. 96k on stock carb setup.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
6adan
Re: Kei Hin Carbs
I was going to ask him to send me the carbs insted of smashing them, guess I am to late buy now.
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
- avg_joe
- My Album: http://s959.photobucket.com/albums/ae79 ... torcycles/
Re: Kei Hin Carbs
I can certainly feel the original poster's frustration. I'm battling with the carbs on my 82. I've had them out at least 4 times, now. PO had been through them, as well. I still don't think mine are quite right, yet, either, so maybe fifth time is a charm?
I had the video and kit when I did the rack on my 77. I almost wore out the DVD...That set went back in, and was good to go. I went back later for the off-idle fix, as outlined in the DVD. That went fine, too.
This 82 has been fighting me from the start! It gets frustrating, and sometimes seems like NOTHING works right.
There have been thousands of them made, and repaired, I know.....That doesn't make me feel any better about THIS one, though. I hope the original poster got his carbs sorted out.
avg_joe
avg_joe
In the garage:
1977 GL1000
1982 GL1100 with California Side Car hack
1982 FT500 Ascot(Wife's bike)
1983 FT500 Ascot
1983 XL600R(with some 85 parts)
1977 GL1000
1983 FT500 Ascot
- Recycled Roadkill
Re: Kei Hin Carbs
I've almost completed a rebuild of a pair of Mikuni 34mm carbs from an '81 Yamaha XS650. These carbs are simple, durable and pretty easy to understand. It's hard for me to understand why the GoldWings carbs would have had to be designed as complex as they are, other than maybe squeezing out every possible bit of HP for the engine.
Honda Civics made in the late 80's and very early 90's have carburetors so complicated that even Honda service techs won't work on them. Technology vs simplicity. Oh well.
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
revolution
- Zinc Member
Re: Kei Hin Carbs
100 man with brain can not fix what 1 man without brain can do ....
