I am a new 76 GL1000 owner and new to this group. I apologise in advance if this subject has been covered before.
My Goldwing idles rough and backfires and misfires, it all over the place at the minute. I have tried setting the timing with new points fitted and balancing the carbs but so far this has had little effect.
I did a compression test today, the engine was hot, the choke off and throttle wound full on as i spun the engine and tested each cylinder. All four cylinders read exactly the same which is good, but if you believe the book the 95psi reading I got was low??
The book says 125-135 psi??
I believe the engine has just been rebuilt with new piston rings amoung other things before I bought it.
Is 95 psi low? If so what do you think the prob could be?
Also when trying to balance the carbs the readings I was getting from the vacuum gauges were slightly low, 0.2 bar (book recommends 02.8 bar) does this sound right to you?
Any help will be greatly received
Regards, Bobted1
