intake capacity
- Dave Allen
- Zinc Member
intake capacity
Hello all. It's been awhile since my last post. Will a single 45mm carb supply enough air to the plenum for the engine to run properly? I'm looking for more economy without a huge loss in power. This carb is a Mikuni and came off a HD with over 1400cc displacement. Cheers. Dave Allen.
48 years on two wheels and counting.
- hmratbam
Re: intake capacity
Should be ok, some of the Webers used on the single carb setups are 36 mm. Be sure and let us all know if you get better milage with it! At the very worst you might lose a little of the top end that isn't used that much anyway.
Ron
Ron
My Album
84 Standard ongoing project
My Album
Re: intake capacity
That might work. It would take a lot of thought for the plumbing though. The carb would have to remain vertical so youd need to make an intake pipe to mate the carb outlet into the plenum. Not impossible at all but would need to be thought out pretty well. Air flow needs to be right for everything to work properly. Especially if you are looking for mileage you need to keep the velocity up at lower RPM for torque.
- Cookie
- RIP: 1950-2011
Re: intake capacity
I don't know where I saw it but somebody did put a big Mikuni on one I think, Saunders?
- jdvorchak
Re: intake capacity
I'm with you cookie. I remember seeing that mod somewhere. Try a google search for mikuni on goldwing.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- Dave Allen
- Zinc Member
Re: intake capacity
Thanks guy's. My first thought was I could plumb the carb into the top of the airbox with a half U bent tube. Run hose where the carbs are supposed to be into the cylinders. My hope is both better fuel economy and possibly more torque off the bottom. This is for my reverse trike project (remember that one?). It has been on the shelf for some time while I have worked on a bobber project (not a wing). I did buy a second goldwing, a naked '82, for parts but again it is too nice to tear apart. under 22,000 miles, had a cracked head but came with new heads and engine disassembled. Cheers. Dave Allen.
- JBz
Re: intake capacity
Hi Dave. Good to see ya back. JB
- Dave Allen
- Zinc Member
Re: intake capacity
Hey JB. Is that you selling the Goldwings in Dayton? Cheers. Dave Allen.
- JBz
Re: intake capacity
probably me but i havent had any luck selling any. 19 percent unemployment is making people think twice about buying things at least it is for me. And they are nice bikes too. I still got your number on my cell. Ill give ya a call and stop by and see your new projects one of these days soon. JBDave Allen wrote:Hey JB. Is that you selling the Goldwings in Dayton? Cheers. Dave Allen.
