Fuel pump upgrade ( electric ) on 1975 K1
Hi all,
I did the needed jobs on my GL1000 K1 like rebuilding carbs, renewing timing belts, Dyna S installation, replacing one ignition coil, rebuilding the 30 A main switch, checking ground and supply resistance all around, BUT the idle was terrible: back firing now and then, rev. changing between 0 and 3000 rpm.
I moved the fuel pump tubes to an electric pump from an Yamaha R1 ( Carb. version !! ), and amasingly the old bike started like a charm and has super cold control with the choke.
I attach some few pictures of the set-up and later the optional electronics to control the pump,
rdgs, Erik
rdgs, Erik
- Simple iron plate to hold the new fuel pump.
- P1000168.JPG (178.68 KiB) Viewed 1652 times
- P1000169.JPG (149.84 KiB) Viewed 1652 times
- The pump placed in the holder.
- P1000170.JPG (182.19 KiB) Viewed 1652 times
Re: Fuel pump upgrade ( electric ) on 1975 K1
nice job. I like the way you think Erik. outside the box, as they say.
H2G2=42
H2G2=42
It is my opinion that most of the members of this site think outside the box , the ingenuity shown on this site is outstanding...this is just another example..
Welcome to the site Erik...what is "RDGS" ?
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
Hi,
Thanx for your compliments, they are always nice to have and to recall later on
I will test the electronic fuel pump control circuit in the near future and upload info here
BTW, rdgs is used in England and is an abbreviation of regards,
Best regards, Erik
Best regards, Erik
- Cookie
- RIP: 1950-2011
Looks like a nice compact pump.
Electric fuel pump now in place ..
- Pump holder in place
- pump_holder.jpg (153.35 KiB) Viewed 1590 times
- Pump on holder plate
- pump_holder2.jpg (172.35 KiB) Viewed 1582 times
I have now tested the electronic fuel pump control "on bike", and it works as intended
In case someone would like to make it, I have added the schematics. It is made with Eagle schematics and PCB design program, just post a message, then I will provide all the files needed to "repeat the success",
- Plastic and electronics
- P1010840.JPG (206.95 KiB) Viewed 1542 times
- Electronics close up look
- P1010841.JPG (226.27 KiB) Viewed 1537 times
- And then the schematics
- Fuel_pump_control_sch.jpg (112.57 KiB) Viewed 1537 times
interesting...
H2G2=42
H2G2=42
- BlueThunder
Why is an electronic control necessary to control the fuel pump? Is this for an EFI setup?
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
It is mostly for safety reasons. The pump is only getting battery supply in 3 sec. after ignition is turned on, and when signals are received from one of coils primary circuit,
- Toehead
Very nice setup you have. Can you share some photos from far away to let us see how it looks overall?
I like your idea of the control circuit. I may build something similar, if I don't decide to do an analog version (Pump runs in neutral and when the clutch lever is pulled, and when the engine has oil pressure , relay controlled)
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
I like this idea of the control circuit. I was able to order all of the required parts (except the relay, which I have on hand) from http://www.mouser.com for less than $20, including the enclosure.
If this is used on a bike with a Dyna electronic ignition, a .01uf cap is needed in series with R4, or the engine will not run.
Mike
So many interests, so little time...
'76 GL1000: "The Super Bee" - finished.
'75 GL1000: Basket Case, Next project in queue
- 10 Replies
- 873 Views
Last post by OCR
- 3 Replies
- 492 Views
Last post by Gowing
- 5 Replies
- 559 Views
Last post by Rat
- 8 Replies
- 662 Views
Last post by boogie red
