Ernie's 77 resto project
Hi guys. If you read my intro you know that I inherited my 77 Goldwing. I did not know its condition until Saturday when I picked it up. Attached is a picture just after it was rolled off the trailer in my driveway.
It doesn't look bad in the picture, but it needs some real work. The first thing I did was to get the bike "naked". Upon closer inspection, I know it needs new tires, brake system repairs/rebuilds, shocks, front fork rebulids, engine seals, routine maintence items, major cleaning, minor surface rust removal and I'm sure a lot more! I really want this bike to look and run great when I'm finished! I have been following Randakks proceedure on restarting an engine. I know that this bike has not been ridden for about 6 years. I got to the point tonight where I was to crank the engine to distribute some oil in the cylinders. After some cleaning contacts etc, the starter spun, but it clearly was not engaging anything. I connected the kick starter and it moved all the cylinders, so I know they are not frozen. I have some knowledge of engines, but I know nothing about these bikes. I am persistant, determined, willing to research the shop manuals and am very coachable! Your help and suggestions are greatly appreciated! They will be needed if I am to get thru this project. ( I already used the electro-rust removal system and could not believe how well it works!) Here is what the bike looks like now. Thanks, Ernie
- starket
Looks like a great start! I'm pretty partial to blue, also! do a search on the starter issue, there are lots of threads about non-engaging starters!
Good wrenchin'
Todd
Good wrenchin'
Todd
Steve, yes those rear speakers were mounted on the trunk. I was told they work, but took them off before the new battery was in place. Todd, thanks for the advice. I'm so new I forgot about the search feature. I did the search and found it may be the oil. I had not yet removed the original. I just took the plug out and oil filter off. When I first removed the filter case there was a small amount of coolant in the oil. How bad is that? The oil looked good when fully drained. I assume those two systems should not be mixing?! Please, please tell me this is normal. Even if its not, I can take it. Ernie
Hey, Ernie! water or coolant in the oil is not good. However, if the bike sat for a while, like it sounds, i'd put off any snap judgements, as condensation inside the engine could be a contributing factor. The first place I'd look is the waterpump, which is right behind the lower radiator hose inlet. directly below that, on the bottom of the engine, there is a weep hole that is the "early warning system" for the waterpump or seal. Often this hole can get plugged with road grime etc. check that out, too.
Down in my sig is a link to a very helpful post, New2U, which covers a lot of the typical issues you could run into. Look thru that, TAKE YOUR TIME, and ask plenty of questions here! Oh, AND HAVE FUN!
Good wrenchin,
Todd
Good wrenchin,
Todd
- tk1971
fun
That's going to be a fun project. Just take it one step at a time and leave no stone unturned. The plastics look good, so you will be saving major cash trying to get original body panels. Also, you've found this site, so you've already save 1/4 of your time looking for info.
Tony
Tony
FAIR is the only four letter "F" word I know.
Rides a 78 GL1000
Rides a 78 GL1000
Thanks for all the words of encuregment guys. I think I'm going to need them. I am beginnig to see what the "Wing" is doing to my life. My job is now just a place I go when I'm not working on the bike. I got home tonight and changed the oil hoping that the starter may kick in. No such luck. I'll have to do some research. Suggestions are appreciated. I also looked for the weep hole under the water pump.
It was pluged and gunked to the max! I cleaned it out. Looked like chocolat milk that came out. Also got some small pieces of metal and rubber. I guess I better pull the water pump and either replace or rebuild. Any thoughts? By the way there are air shocks on the rear. On the tront at the top of the forks there is an air gauge. It does not appear to be connected to the rear shocks. Is this connected with the front shocks? Thanks again. Ernie
I would get it running if possible before tearing into the pump. An easy way to check and make sure it is not going to grenade is to pull the outer cover ( where the lower hose attaches) and stick your fingers in there and wiggle the impeller blades. A small amount of rotational play is ok but zero sise to side play on the shaft itself.
For your starter changing the oil is not going to fix it unless the engine is running. The clutch in there is engaged by centrifigual force. It is a sprague clutch design, there are three roller bearings that engage the outer basket to spin the engine. The least bit of Varnish or crud can make those rollers stick and when it is spun they will not engage the outer housing. I would do all my other maintenance and then get the bike running either with the kick starter (very unlikelly on a resurection) or call a couple of buddies over and try push starting it. Once it is running exercise the starter with the bike at idle. Engage it several times and listen as it runs up. You should be able to hear it reach peak rpm and release it. Do this 10 -15 times. Shut the bike off and test it. It may respond better to a flushing agent than standard oil. Drain a quart of Oil and add a quart of Marvel Mystery Oil (MMO). Just use caution not to rev the engine too high as the MMO will dilute the protection on your main bearings and cam journals.
whiskerfish, Thanks for the help. I can't really see myself pushing this "bad boy" to get her started, but we shall see. (Especially since it doesn't have any brakes!) My plan was just to do enough to get a compression check. That way I would know if the internals were ok. Then I was going to start tearing down and replacing and rebuilding. It seems however that I need to do some other work just to get the compression check. I'll take care of the gas issue and check the water pump as suggested. However at this time I'm not getting any spark when I use the kick starter (and obviously not when I hit the starter as it is not engaging). The bike has a dyna, so there are no points. I'm not really sure where to begin to check the ignition situation. I understand the basics but do not know how to check the individual components to isolate the problem. If you or anyone can help it would be appreciated. I hate to keep asking for help all the time. Maybe this portion of the project is over my head! Thanks, Ernie
Good news and bad news. I drained the fuel tank. It was full of rust. The integrity of the tank looks ok, just a bunch of rust and gunk floating around. Is it best to take out the tank and do the Mr Wizard science de-rusting or should I tackle it another way? I also removed the water pump cover to check that. I was told that there should be no side to side movement. WRONG! It wobbled all over the place. Probably had more than 1/8 inch side to side movement. I guess that means that I will drain the oil again and start the water pump replacement routine. Now for the good news. I started cleaning connections and checking wires etc. I tried the kick starter and lo and behold, SPARK! I was so happy. Those other problems are mostly wrenching. The electronics have me a bit bewildered. I'll keep plugging along and keep posting. Ernie
- TomE
- My Album: http://www.ngwclub.com/gallery/v/wingmans/TomE/
Tom, I spent 3 years restoring a 63 Cadillac and 58 Thompson, so I know about "the list". I found that I don't mind doing these things, but I hate RE-doing them! Thanks for the heads up. I even thought about spending the $100 or so to buy a complete gasket/seal set so that I have them when I need them. If I don't I'll end up buying them piece by piece. What do you think? Ernie
- TomE
Hi polkadot77,
As a guy who also restores boats, I really like that Thompson. Nice work!
And I have good memories of cars with really large fins. The car I drove in High School was a '60 DeSoto, with a push-button automatic transmission and really huge fins.
Hard to say on the gaskets. The best prices seem to be from Service Honda, and they take a while to ship. If you can predict what you will need, or don't mind extra gaskets, pre-buying can work out.
TomE
Big Red, a '75 Wing
Black Beauty, a '99 Valkyrie
Big Red, a '75 Wing
- 18 Replies
- 950 Views
Last post by rnelson
- 12 Replies
- 886 Views
Last post by Track T 2411
- 49 Replies
- 4537 Views
Last post by pass_the_bacon
- 27 Replies
- 2791 Views
Last post by 82aspy
- 43 Replies
- 9116 Views
Last post by tomk1960
