GL1100 shifter
tmon
GL1100 shifter
Does anyone know the size of a shifter for a 1982 GL1100. mine was replaced by the previous owner. for a heal toe shifter, and i would like to put the peggs back on. or does anyone know of alternative bike to use.
Catching a yellow-jacket in your shirt at seventy miles per hour can double your vocabulary.
Four wheels move the body. Two wheels move the soul.
- Sagebrush
I see shifters for 1100s come up on EBay all the time. Also, give Cyclepsyhco a call. He probably has some. http://www.cyclepsycho.com/
bum
I think they are interchangable with the 1000's, after looking at them side by side it looks to me that the only difference is that the 1100 shifter looks thicker/wider . I'll try the 1100 shifter on an 1000 engine if they are different and will not fit I'll repost and tell you or pm you. 8)
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
- HorseFly
- Zinc Member
puffy75
- Early 'Wing Guru
- My Album: http://www.ngwclub.com/gallery3/index.p ... ns/puffy75
All of Honda's shifter shafts are the same size, so any shifter you like will fit the shaft. The bend and length are things that need considering. The GLs have an extra item to consider, it is clearance between the exhaust pipe and head.
May The Fours Be With You.
CB77 1965 First Bike
GL1000 1975 "Puffy" damaged in accident
CB750F2 1978
GL1000 1976 "Puffy Too"
CB750F2 1978
- Gary1945
Heres one on Ebay right now for sale.
http://cgi.ebay.com/ebaymotors/1981-Hon ... enameZWDVW
Its about $25 ppaid.
Gary Andrews Sr. 1981 GL1100 Standard
