Page 2 of 2
Re: Cable Shortening made EZ
Posted: Thu Nov 03, 2011 9:25 pm
by CBX n GL man
Helpful thread here, going to need shortening of the cables for my CBX when I put on shorter bars, cool. Later.
Countersink tip
Posted: Fri May 10, 2013 9:30 am
by haley5586
I had my clutch cable break after doing this a couple weeks ago. The cable worked it's way out of the hole in the barrel so I had to come up with a more reliable solution.
I found that by countersinking one side of the hole in the barrel you could improve the strength greatly. I took a larger drill bit and drilled about 1/3 of the diameter of the barrel. This way you can fill that cavity up with more solder than before and it won't sqeeze through!
After doing this I must say; It's very nice to have confidence in my throttle cable again!
Pics are barrel, barrel with cable stuck through to previous edge of diameter, and after soldering and filing to shape...
