Cable Shortening made EZ
CBX n GL man
Re: Cable Shortening made EZ
Post #16 by CBX n GL man » Thu Nov 03, 2011 9:25 pm
Helpful thread here, going to need shortening of the cables for my CBX when I put on shorter bars, cool. Later.
'81 CBX nekid
'80 GL1100 w/windjammer
'80 CX 500D 1/4 nekid
'84 GL1200A 1/2 nekid -- gone
haley5586
Zinc Member
Zinc Member
Countersink tip
Post #17 by haley5586 » Fri May 10, 2013 9:30 am
I had my clutch cable break after doing this a couple weeks ago. The cable worked it's way out of the hole in the barrel so I had to come up with a more reliable solution.
I found that by countersinking one side of the hole in the barrel you could improve the strength greatly. I took a larger drill bit and drilled about 1/3 of the diameter of the barrel. This way you can fill that cavity up with more solder than before and it won't sqeeze through!
After doing this I must say; It's very nice to have confidence in my throttle cable again!
Pics are barrel, barrel with cable stuck through to previous edge of diameter, and after soldering and filing to shape...
Current Project; 82 nekked wing "Glinda"
05 VStar Custom "Wicked Witch"
82 KZ440 "Tornado"
Who is online
Users browsing this forum: No registered users and 2 guests
