So I have a 77 gl1000 and if I forget to put it in neutral before I shut it down, it is very difficult to put in neutral. I am not saying to remove the switch because it has its purpose ( in my case its off all the time. I havent checked the bulb yet though) but this bike is 33 years old and i'd like a failsafe. that being said, could a spst switch be installed inline and when the switch fails or in my case I forget to put it in neutral you could open (if I read the post right) the spst switch to be able to start it while holding the clutch in.
or am i just being dumb.
2011 Triumph Rocket 3 Roadster (Totalled)
2008 Triumph Rocket 3 Standard.
1977 gl1000 cafe project for my brother
1993 xr250l 280 kit
1968 Husqvarna 250t Commando (Needs a lot of work. been sitting outside since 1971)
You clutch switch should allow you to start the bike if that is what you are after. Just pull in the clutch and the bike should crank.
To check if the clutch switch is bad Check and verify continuity to ground from the Green / Red wire terminal at your clutch switch when you pull the clutch. If you do, the switch is OK.
If not, next verify the green to ground continuity, (won't matter if the handle is pulled on that one). If good there, you have a bad switch. If no continuity on that wire trace the green wire to find the open.
You mentioned that you had trouble "burning off" the carbon.
I did as well. I had 12 volts applied directly to the switch (in 1st) for 10 minutes or so. It was pulling about 600 milliamps the whole time, but did not "burn" off and the light was still on constantly.
I then put another car battery in series with the bike battery, and applied 25+ volts to the switch while it was in 1st. This time I got a tiny spark when I hooked up the wire to the battery, and then nothing. A quick check shows that the light is now off in any gear except neutral.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
Toehead wrote:You mentioned that you had trouble "burning off" the carbon.
I have done that fix on a couple of bikes but it never lasted for me. Seemed like within a few days or weeks the switch was failing again. Just so you are not surprised if it comes back
Thanks for the heads up. I'll post an update after some more riding. If it lasts a month I will be happy. It only takes a minute to do, so I don't mind redoing it.
1980 CB750C (sold)
If the neutral light is on and my bike cranks over fine that is good right? I bypassed the clutch ground (wired them together with a twist),
but not the neutral ground and I have no spark and the only thing that is left are the coils being totally shot. Am I missing something? This is my first rebuild and I am a total newb at electrical systems as I have only ever ridden two strokes and bicycles.
- 1978 GL1000 on its way to being a blacked out original.
There are several possible causes for no spark. I would start a thread in the tech area and give us as much information as you can regarding what the condition of the bike is and what you have done so far and we will be glad to try and assist you.
