Page 1 of 1
FS: Keys cut by Code
Posted: Sun Aug 10, 2014 8:23 pm
by Keymaker
Keys cut by code are only $5.50 each.(includes shipping)Click here to order.
Keys for vintage Goldwings cut by code (and numerous other Honda's that use the same key blanks) 5 number, 3 number, and A00-D99. I can also cut keys for aftermarket ignitions that use H00-H99 codes. (Most aftermarket ignitions do not have the code on the lock, only on an original key.)
**NOTE** If lock or key has been altered, the code may not work.
If you have a working key and no code, I MAY still be able to help.
PM or email me at codecutkeys@gmail.com .
Available blanks, subject to change based on availability.
For 5 number codes (75 and 76 only. Brass or nickel plated.)
for 3 number and A00-D99 (77+)
Here are a few locations of the key codes.
A 75 or 76 ignition lock code 77890.
A 75 or 76 helmet lock code 29087.
A 77-82? ignition lock code 117.
A 78 or 79 Shelter cover code 508.
A GL1100 trunk lock code 616.
A 82-83 GL1100 saddlebag code A31.
A GL1100 cover code 314.
A GL650I luggage lock code 813
Re: FS: Keys cut by Code
Posted: Mon Sep 28, 2015 5:42 pm
by rtccp
. Hello keymaster...I'm looking for keys for my early 80's gl1100 samsonite hard bag lock...the key code is 17087... Do you have any of these???.. Nick
Posted: Fri Apr 13, 2018 11:17 pm
by frankroche
Would an original key say DO9?
Posted: Sat Apr 14, 2018 1:51 pm
by roncar
D09 is a valid key code for 83 or newer bikes and many replacement locks (ie helmet.)
Posted: Sat Apr 14, 2018 1:55 pm
by calif wingnut
He was last active one year ago. Try sending him a message.
Last active:
Mon Apr 17, 2017 1:39 am
