Be careful when removing your GL1100 carbs' float bowls. It is often necessary to rap on them with a tiny hammer or the handle end of a screwdriver, but be careful. It is not uncommon for one or both of the bowl's registering nubs to snap if you tap too hard. Word to the wise.
Mikee Minute #3 -- Care removing float bowls
- mikenixon
- Early 'Wing Guru
- Lead Member
Re: Mikee Minute #3 -- Care removing float bowls
Testing reply
Admin
Admin
- mikenixon
- Early 'Wing Guru
Cool!Joestrm1 wrote:Testing reply
Admin
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
- calif wingnut
Hi Mike. You sure that's an 1100 bowl ?
- DSCF3739.JPG (115.97 KiB) Viewed 462 times
- mikenixon
- Early 'Wing Guru
Hard to tell. I would have to see the bottom. If the pictrue wee clearer...is that a broken off standpipe or just the casting boss?
Mike Nixon
- calif wingnut
and if so, no wonder I messed up the queens 1100 in 81 ~:<)
- DSCF3446.JPG (105.07 KiB) Viewed 457 times
- mikenixon
- Early 'Wing Guru
Cool! If you're going to pick on my picture, you should point out that I obviously forgot to check the white balance before taking the pix.
Mike Nixon
- calif wingnut
Btm side.
- DSCF3742.JPG (117.64 KiB) Viewed 434 times
- mikenixon
- Early 'Wing Guru
Is this a test? . Looks like a Wing float bowl to me.
Mike Nixon
- 474 Views
Last post by dbtroudy
- 22 Replies
- 642 Views
Last post by chrisz
- 8 Replies
- 284 Views
Last post by Placerville
- 35 Replies
- 783 Views
Last post by sunnbobb
