The Resurrection of the Americo J. Policarpo; a '76 GL1000
- Tin Member
I picked up my latest project this weekend, a 1976 GL1000 in Sulfur Yellow. Bought it out of a barn in the countryside.
I was going to title this build thread Old Yeller until I realized that is what ALL other yellow '76s are called. Hence, the Americo J. Policarpo, named in honour of the bike's previous owner. I got his name off the most recent registration (1987, which jives with the registration sticker on the plate), and I know very little about him, other than that impressive name, and the fact that songs were once sung about him.
This is the bike, freshly arrived home. Still dressed in the Windjammer.
And once I removed the fairing. Very happy that headlight is still under there.
Nasty surprise under the hood. The glove box insert was missing, and in it's place a mouse had built this lovely home. The area around the filler neck was clearly the bathroom.
I drained and replaced the oil. Only about 2 quarts came out, and it was very thin and runny despite being pretty cold. Some pretty thick sludge present in the filter though.
The bike is sporting these strange aftermarket air shocks. There is a line connecting both shocks to a gauge and valve attached to the handlebars, where I assume one would add and monitor air pressure. However, there don't seem to be any check valves present, so a leak anywhere in the system and you're suddenly without suspension. Seems less than safe. The gauge says "Reeder Gaspring" but I couldn't find anything about them online, so I suspect they didn't last. In any case, the hoses have long since gone brittle and broken in places, and the shocks themselves are horribly rusted, and without any air in them the bike was very difficult to move around. I have shocks from the '78 parts bike that I can throw on for now.
I suspect that these weird, failed shocks were at least partly why the bike was parked in 1987 and not ridden since.
1976 GL1000 - Sulfur Yellow - Project Bike
1985 GL1200 - Two-up camping bike
1976 GL1000 - Future project (maybe a rat cafe...)
1978 GL1000 - Parts bike
Lots of other non-GL Hondas
- Tin Member
Re: The Resurrection of the Americo J. Policarpo; a '76 GL1000
The ignition switch was also broken and wouldn't pass power, but when I bypassed it I got some life from the taillight! Always nice to see some signs of life.
Currently the bike is lying on its side while I try to free up the pistons with the old ATF and acetone mix. If that doesn't work, I have a line on another 76 in pieces that I plan to pick up this weekend. Apparently that engine turns over, at least.
Looks like a pretty solid bike to start with (hopefully the engine isn't solid, too!). Nice, cozy nest, lol! I bought an '81 that had the air box packed full, as well as the fairing. It reeked! My most recent bike had acorns and walnuts shooting fifteen feet out of the exhaust when I first fired it up, lol!
- Tin Member
Yes, there’s a smell to it that I previously would have identified vaguely as “old barn or shed”, but I will now go the rest of my life unable to ever forget the smell of concentrated mouse shit.
- Chainman
Cool, a thread with a theme song.
Thanks for sharing; enjoy your project.
It is a great name.
It is a great name.
are you sure you have enough experience to do this?
I'm not seeing many power fist tools laying around or even worse..no tim's cups..
- dontwantapickle
a live possum has a real stench as well
how is the resurrection of Polycarp going?
Paola (Italy)
Paola (Italy)
the shocks most likely were S&W which really were not all that good, bot better than OEM (I have a set I can sell you).... the gauge was to help you know how well they were set... anyway they rode like sitting on a brick!!!! not that the OEM shocks were good as they sucked as well
- Tin Member
Not too much to update, I’m afraid. My efforts to free the engine with magic oils and potions has not been very successful yet.
I picked up another ‘76 in the meanwhile. Rougher shape cosmetically (the original red had been covered with a metal flake brown) and higher mileage, but with an engine that turns over freely. I’m sure between the two I have enough to put one very original bike back together, and maybe even enough left over to help put the ‘78 together as a stripped down version.
I also picked up a motorcycle lift (deeply discounted floor model from Princess Auto). That should increase the Power Fist quotient enough to satisfy some.
A question: is the major difference between the early and late GL1000s basically in the carbs and cams (aside from the kick starter delete)? And if so, can a ‘78 engine block be fitted with the carbs and head from an early bike without too much trouble?
You've pretty much detailed the major differences (aside from cosmetics). Swapping back and forth can be done with abandon. No issues at all with the 1000s. I've got a set of early cams that I'd intended to install, but never got around to it. They're supposed to be paired with the early carbs, as well. Either way you should not have issues mixing and matching.
Isn't the ignition timing is different between the early and late years? I seem to recall posts about having to mark the flywheel, etc...desertrefugee wrote: ↑Tue Dec 22, 2020 11:49 pmYou've pretty much detailed the major differences (aside from cosmetics). Swapping back and forth can be done with abandon. No issues at all with the 1000s. I've got a set of early cams that I'd intended to install, but never got around to it. They're supposed to be paired with the early carbs, as well. Either way you should not have issues mixing and matching.
Hmm. You know, I think you might be right! But, isn't one or the other crank marked for both? I don't recall - but again, a savvy shadetree mechanic can get around that and mark his own flywheel. It has been done lots of times.
- 18 Replies
- 1665 Views
Last post by cbrianroll
- 36 Replies
- 3481 Views
Last post by Bkreaume
- 32 Replies
- 4410 Views
Last post by pidjones
- 49 Replies
- 4038 Views
Last post by Patriccio
